Ordered discs and pads all round for the Merc. Much obliged to Jason at Allgerman for his service. Have only heard good things, so nice to experience it first hand...
Parcelforce permitting,  I should be busy on Boxing day  8)
BazaJT
Having taken Maureen to her grand daughters for the day I've returned home and replaced thermostat.Was a bit worried about this as I've heard/read much on here re the "B" bolt.However every thing has gone smoothly with no more hassle than I'd normally expect when working on a car.Running engine up to temp and sorting out coolant level all seems watertight and dry-time will now tell!
Quote from: BazaJT on 25 December 2014, 13:57:24
Quite a satisfying job, that ;)
Don't forget to set the heater temp to HI/max otherwise you'll get a coolant level warning when you first use the heater as it still has air in it... :y
BazaJT
Yes set temp to max to avoid the very thing of which you speak.Still good to have a "heads up"though.
Used it as a taxi , roads empty and slippy   :)
bored bigyin54
Discs and pads all done, parking brake requires tweaking, but same design as Omega but with three times the adjustment, so requires alot less effort to adjust it 8)
Job for another day though as the weather is king horrible now...
Shackeng
Did 40 miles in 2 hours in the rolling car park on the M25 yesterday back from Kent, then did the last 70 miles in an hour and a half. :y :y :y
Put some oil in the Bullet to stop it moaning. Not before I had myself some slow speed fun on the icy roads.
Stalled the Battlebus by parking too close to the Bullet running on high idle, heck of a job to restart.
Took Battlesbus down the tip...   ...but brought it back :P
Cleaned up 3 out of 4 threads on some bits that need fitting.
Also put a load of mould killer on the Battlebus, and slapped the Bullet on charge. Again.
Lagondanet
Started it up. First time since Christmas Eve. Filled it up & checked the tyre pressures. Ready for the commute to London in the morning.  :y
Webby the Bear
Off to Edinburgh for Hogmanay festival tomorrow. So pre-journey checks completed. Slight coolant top up needed  ::) ;D
Fluids and spanners in boot.
Petrol and tyre pressures at morrisons tomorrow morn :)
RIP Paul Lovejoy
Webby the Bear
Oh and cleaned and oiled the 3.0 engine in the garage as was starting to look a touch rusty.
Turns over real nice!
RIP Paul Lovejoy
ted_one
Cleaned 2 of 3.....thinking will do the other one tomorrow. Just got back from OSP after picking up a couple of urgent bits, should have taken the car that needs cleaning.....-4 degrees M4 salted and clean car now covered in the stuff. Bo**ocks ???
At least the wheels will scrub up a treat :y nothing eats brake dust like road salt 8)
