Quote from: Taxi Al on 06 January 2015, 17:26:26
Quote from: TheBoy on 06 January 2015, 17:23:56
Used the Bullet for work today, and not had to fill the boot with spare coolant :D
Bet that was a LOT of fun 8)
Fixed
Quote from: ffcgary1 on 04 January 2015, 17:25:58
Finaly got round to repairing the non working front speakers on my 2000 XJ cherokee, passenger side was just a bad speaker, but the drivers side was a broken speaker wire in rubber flexi boot. fitted a pair of pioneer 17cm duel cone jobbies. job done.
still got a list to get through though, hey ho the joys of jeep ownership.
Gary :lol:
Mite need some advice then if this auction goes to plan  :-\
4x4
1st proper drive out in truck today since redoing the timing,now pulls far better and sounds so much better  :y
Lagondanet
Had a front screen chip repaired. Same place as last August so free.  :)
Quote from: Lagondanet on 09 January 2015, 14:11:49
Mrs TB has wrecked another bloody windscreen.  Still, the fitters made a poor job last time, so maybe its not so bad :P
ronnyd
Took mine for a VIC check after being written off as a CatC. £41 for 10mins, not a bad deal for VOSA. :(
Pulled a decent birds nest out the exhaust  :)
Shackeng
Changed oil, filter, air filter & pollen filter on SWMBO's Jazz. 6000 miles since last service , but.....21 months! :-[ :-[ :-[
Pressure washed the boot gullys on the Bullet, and reminents from the granding/welding had got in there, stuck, and started to rust :o
Shackeng
Connected the solar panel to the OBD socket on the Elite, as I probably wont be using it for a week or two. :y
Arsed about with the handbrake. Should work - well enough for one go on the MOT rollers, at any rate. :-X
Spotted all of the pipe clips on the LPG line had rotted away to nothing. :o Replaced the critical ones. Mental note to buy more P clips. Plastic ones!
Fixed the number plate light that fails on the way to every MOT, and then again about 2 weeks after. >:(
Oil and filter changed.
Painted some waxoyl onto those LSC springs.
Wiper blades changed.
Rear headlight levelling sensor replaced.
Polished the headlight lenses so you can tell if the headlights work. ;D
Bit on the mum bus...oil and filter change, Cleaned the EGR and boot valve.
Looked at fixing the numberplate hinge/spring. Decided it needed parts, so ignored it !
