Car is four years old, with original discs which should have been changed at the last pad change :-\
tidla
Quote from: Taxi Al on 30 November 2014, 19:16:07
Tried and failed to change the rear discs on next doors Octavia :-[
Stupid eejits at the factory must have welded the caliper carrier bolts in, so even on ramps, you can't get enough leverage to undo them with a two ft breaker bar >:( not that there's room to actually use a breaker bar on them in the first place :-X
I can only assume the hubs are completely built up before fitting to the rest of the suspension :-\
Thats cus if its the same as the other Vags, just idiot the disc and it slithers out round the caliper carrier.
Being a VRS with larger diameter discs, there isn't the room to do it... also discs are welded to the hub, and without the carrier removed, there's no wacking room :'(
Washed the 2.6 as it did 986 miles last week (including an install at a new development that can only be described as still a building site) so it was a little dirty!
Repaired two door looms on the Alhambra, now have speaker in drivers door and n/s rear window working.  :y
Wedged a bran new tool trolley in the boot , cant get it out now  :-[ + ripped the tax disc holder out .
finally for the omega
changed the starter, front hubs and installed new wishbones with poly bushes and tracking done :)
must admit handling changed with those poly bushes.. :y
Quote from: cem on 01 December 2014, 16:12:43
I reckon front polly's is the best mod to do on an Omega, followed closely by stiffer springs and better shocks.
Quote from: VXL V6 on 01 December 2014, 18:18:17
they are in the que.. clit needs cambelt change and a new boost meter.. and I plan to change 2nd and 3rd gear ratio for omega :-\
Mr Gav
chrisgixer
No need to remove wishbones to fit polys though. Half hour a side. Just make sure the jig saw blade is sharp. ::) ;D
Quote from: chrisgixer on 02 December 2014, 09:51:31
old wishbones were pattern and gone to the bin ;)
bought a 710N diverter valve for clit and replaced the 710P.. holds the boost a bit more, before it opens..
joff
Did the cam cover seal on the drivers side (135), 6 new plugs and breathers to do tomorrow with an oil change and air filter change as I have a Scotland trip next week.
2 new tyres on my van I just got after the MoT yesterday and the tracking on that as well
Wiped all the green shit off the plod estate :-[
Call me gay, but I wasn't going to wash it in 4 degree drizzle... ::)
Can you come and do the RX8? I think it's starting to grow moss in the rubber seals..
