Delroy47
Cam belt, water pump and thermostat changed  :y
ronnyd
Gave it a good clean, then SWMBO wanted to go out, country lanes, filthy again, bugger. >:(
steve6367
Quote from: Taxi Al on 08 February 2015, 20:11:55
Got the Albanians to wash the Oxymoron and slapped some polish on it ready for Tuesday...
Is that the 2.2 and Sport in the same description  :D
Quote from: steve6367 on 10 February 2015, 23:02:05
Textbook definition  ;D
Been told my irregular knocking noise is the DMF :-(
Only on start up or also when clutch is pressed?
All the time in neutral. You can kind of feel it when you touch the clutch pedal
Any knocking when started up?
And movement in the gearstick when you accelerate hard in gear?
Does a bit thinking about it on start up. Not notice gear stick movement
Yep. Sob. Not gonna be cheap. They reckon 9 hours labour!
Can probably do it in a day if you need.
Make sure you get a Sachs DMF
Cheers. They said clutch and slave too?
