Yes full kit plus flywheel bolts and clutch fluid.
Shop around  :y
Will also need gearbox oil
Ecp website baffling me with choice already!
Steve B
Quote from: Taxi Al on 10 February 2015, 18:45:11
Sold one... and collected its replacement... ::)
And as I know you're all clamouring for pics...
Here's a taster...
;D
Still waiting  :)
Steve B
#9514
sick of bleeding waiting  ;D ;D ;D
PS are you happy with it...... :-\  is there Much to do  :y
At least you can see the car in that pic :P
I shall take some sensible ones on Sunday if I get five minutes :y
Abandoned my lovely, comfortable, relaxing bullet at Bicester so I can use the uncomfortable, expensive, late Chiltern Slug to go to that place that turns your bogies black :(
Replaced the temp sensor wiring in the fog lamp loom. She now has a working sensor again.
2boxerdogs
Timing belt & all ancillaries all done today, so should last till I retire completely now !! The trouble is what do I replace the 2.6 with then ?
amba
Fitted new H7 Nightbreakers to high beam on both headlights .Lets see if their is an improvement and n/s high beam is at a better direction not up in the trees  :(
joff
joff
After fitting the Depo HiD to the MV6, am now in agreement that they are crap, so have been spending my 12 hours off today trying to build a good rear body out of the spare HID's I have so I can fit the new lens to it tomorrow. Will not be buying any more Depo headlights they are S$%T
Fitted new washer 'heater' loom and replaced melted passenger washer jet, replaced melted passenger scuttle panel and replaced melted vac pipes, sealed scuttle.   :-X
Removed headunit, modified it, reinstalled it, replaced ashtray with modified one with extra functionality.  8)
Broke 3rd Party sat nav aerial connector for NCDC  >:(
Washed number plates and lights as they had disappeared.
