Quote from: Jimbob on 02 March 2015, 12:08:00
Quote from: Marks DTM Calib on 02 March 2015, 08:32:14
Finished off the clutch replacement job, everything fitted back on and all good.  :y
Hugely appreciated, many thanks :)
Look forward to geting it back....although that will mean my stint of 3.2 mv6 fun is coming to an end ;)
Oh, yes, I know that. That feeling of disappointment of knowing you won't be using the Omega, and are destined for a life of boredom in a Zafira ;D
Top marks to Mr DTM, saving a member a (most likely nearly uneconomic) expensive repair bill :y
Quote from: TheBoy on 02 March 2015, 17:28:43
Indeed, Garage bill would have been a bit on the large size....
Im glad I wont be paying the omega fuel bill for the extended use for much longer though!
Quote from: Jimbob on 02 March 2015, 17:44:27
But its worth it. I just look at it as one of the few little luxuries I can treat myself to :y
Quote from: TheBoy on 02 March 2015, 17:50:35
I did too till my milage increased too much, still least we have the one for those special occasions :)
Running 2 x 3.2's just wasnt doable any more, Hers is going nowhere.  Its her baby.  Wanted from when she first saw it at the first lake meet.
plym ian
Went for mot today, it passed had a few advisories so pleased all round :y
EMD
Changed all 6 spark plugs in 10 minutes  :D :D ;D All plug wells bone dry  :D :D ;D
Omegatitis
Seth
Seth
Quote from: Taxi Al on 03 March 2015, 20:38:16
Nice one :y
Cheers Al! ;D
Found a front coil spring broken on the trusty VW Caddy van later this afternoon >:(
Thought things were going too well here ... on the vehicular front ... :o
Went to change the oil, then hid in the garage under the pretence of tidying up. Opps me that wind is cold.  :'(
;D
2boxerdogs
Washed polished & vacumed the 2.6 now tucked safely in the garage, not using it for 10 days as got some time off. 😀😀😀
4x4
Removed cam cover/gasket,stripped down front of engine to find oil leak,changed both camshaft seals,and cam gasket,seems to be leak free again  ;D
4x4
Also did oil/filter change and changed sump plug :y
minifreek
Found out the MoT is due on the 10th of next month...... needs quite a bit of work I reckon to get it to pass...
Put some water in the header tank, seems the old problem of using water has come back.... time to change the HG's I guess.... :(
On the upside - got some good news about some alloys I'll be purchasing sometime in the near future :)
D.I.L.L.I.G.A.F...
EMD
Put an LED festoon bulb in the interior roof light... wow thats bright  :o :o ;D ;D
Omegatitis
