joff
It was MoT day for the Elite and after putting 4 new tyres on and checking all the brakes and lights, the very nice man(not) at the MoT test station failed it on O/S front wheel bearing rough when rotated !! Also 2 advisory items
1 front brake pads wearing thin ( 5 mm left on all pads, new ones are 11 mm thick) ? So just under 50% worn !!!!
2 front to rear brake pipes greased ( I know I did it yesterday)
Went home to check bearing which when disc removed runs as smooth as you like.
New bearing on its way for the morning, I'm also fitting new discs and pads as I have a set here. The old discs still have 1.6 mm to go to minimum thickness of 25 mm.
After car passes tomorrow afternoon I think I may be having a word with the very nice man who does MoT.
Bet he says summat about not having the benefit of removing pads to check them... surprised he didn't say anything about the sill covers while he was at it ;D
joff
Quote from: Taxi Al on 20 March 2015, 18:54:26
Think I've had that before about sill covers. :y
When you know that the advisories are an arse covering exercise, you simply ignore them.
tigers_gonads
Quote from: joff on 20 March 2015, 18:51:37
New bearing on its way for the morning, I'm also fitting new discs and pads as I have a set here. The old discs 2 front to rear brake pipes greased ( I know I did it yesterday)
:o  I've been emptying half of can of white grease on mine every year before MOT time and never been picked up  ::)
Sounds a little over keen to me
joff
Quote from: tigers_gonads on 20 March 2015, 18:59:18
I don't mind a little over keen if it's something I have missed, but I have been an engineer for many years now and it gets to me when items are picked up so the garage thinks they are going to make a few quid when it's not needed.
joff
Quote from: joff on 20 March 2015, 19:13:27
New MoT with no advisory's  :y today
EMD
Took all the gearbox connectors off and cleaned them , noticed a chafed abs wire to the front sensor  ::) Got too cold , locked it kicked it  :(
Omegatitis
Drove it up and down some hills, and around some puddles...
EMD
Dash out , replace 5 blown bulbs and a bit of soldering on the circuit board .. downside the air bag bulb was permanently on  ::) Fixed that , just a loose wire  :)
Omegatitis
minifreek
Got pissed off coz Iv convinced myself that one of the HG's needs replaceing....
Going to have to get them done before dragging the caravan down to Billing in July....
D.I.L.L.I.G.A.F...
Left it at home to join the faceless hoard...
EMD
Quote from: minifreek on 23 March 2015, 07:22:13
My caravan needs dragging out to fix in some beds and interior walls   :-[
Omegatitis
Drove it to some Heritage Line. Chose To get on one with a steam loco over the diesel ones in order to make MDTM stomp his feet ;D
Lagondanet
As usual and as part of the faceless hoard drove it to London 45 miles and then back 45 miles and didn't spot another friggin Mig.
;D
