What should TheBoy do with his 2nd Tech2
Started by TheBoy, 01 July 2007, 09:56:59
I'm only half - serious, realistically I wouldn't use it nearly enough to justify holding it.  And no, I didn't PM Jaime asking for it :)
Taxi_Driver
I did think about buying it from TB......but i would need it to do CAN which i think is another load of dosh for the upgrade  :( And i still havent found out if the tech2 can read dual fuel ECU's.
VeccyC is going to vx dealer in Bath shortly for LPG issue......must remember to ask or even see if i can get a peek at the kit they use.
QuoteI did think about buying it from TB......but i would need it to do CAN which i think is another load of dosh for the upgrade  :( And i still havent found out if the tech2 can read dual fuel ECU's.
A CANdi is expensive, usually around $500 - $600, and is required to do Astra-H, Veccy-C, and Signum.
As for Duel Fuel, if ever you get a fare over this way, we can always give it a go :)
I'll hopefully bring veccy over weekend after next, so we can test it on that....
Taxi_Driver
That would be interesting experiment.....but if it can i dont think it will prove that a tech2 will read the veccyC lpg ecu.... :-/ but would be worth a visit to TB's first before dashing off to the vx dealer in Bath  :y
One question.....
Why / How have you got 2 tech2's?
QuoteOne question.....
cause he is a greedy bugger  ;)  ;D
hotel21
Wheres the option for a raffle?
£10 a go, times roughly 500 peeps - thats 5 grand!!!
Taxi_Driver
QuoteWheres the option for a raffle?
Thats a good idea.....you could always include a condition that if a least 180 people dont buy a ticket.....the raffle is cancelled and tenner refunded  ;)
Admin
Not a bad idea.... :)
I'll have 2 tickets!
The Administrator.
fuz1903
Forgive ignorance but what is a Tech2 and what does it do? :-/
QuoteForgive ignorance but what is a Tech2 and what does it do? :-/
tech2 is the unit used to talk to car's ECU, used on nearly all Vauxhall's
It reads fault codes, gets information from sensors,
Timbuk
Good idea :y
You saw the for sale one, in fact it was plugged in your motor
Hmmmm  :-/ - thats an idea ;)
Would that count as gambling, and would I need a licence?
