Author Topic: Omega to Veccy audio swap?  (Read 1160 times)
« on: 26 July 2007, 14:06:22 »
Just wondering, Veccy only has a tape player
How feasable would it be to fit the CD changer, head unit, etc from my Elite? Would I loose steering controls and MID integration?
Are the MIDS the same between Omega and Veccy?
Re: Omega to Veccy audio swap?
« Reply #1 on: 26 July 2007, 14:35:05 »
Should work, father in law has a vectra with the same audio as the mv6 had, except a 4 disk changer, not 6.
Easy enough to swap just the head unit to prove you have functionality, then you could do the trickier bit of the changer.
« Reply #2 on: 26 July 2007, 18:35:39 »
i suspect your veccy has newer style MID, so can't use elite one.
If your radio supports steering wheel (which sc804 does not), then tech2 can program in.
