Blanking plate
Started by JamesV6CDX, 16 December 2009, 15:54:57
I need a blanking plate, to fit to the plenum, blank off where the EGR valve would use connect to the plenum.
Time is very tight, so I'd gladly pay, if someone could make me one.
Anyone fancy earning a few quid?  :y
QuoteI need a blanking plate, to fit to the plenum, blank off where the EGR valve would use connect to the plenum.
Where are you tying the EGR up afterwards?  :-/
Well, I might just fit the blanking plate, to seal the plenum, and then put the valve etc in it's original position
gra11
If you go into any vauxhall dealership they will sell you a blanking plate. As they have them as a stock item. Then instead of the gaskit you would replace it with this and the egr valve bolts straight on through it again. If you do not have the egr valve connected the engine management light will be constantly on  ;)
If you ain't fast! Your (in a diesel)
unlucky mark mv6
QuoteIf you go into any vauxhall dealership they will sell you a blanking plate. As they have them as a stock item. Then instead of the gaskit you would replace it with this and the egr valve bolts straight on through it again. If you do not have the egr valve connected the engine management light will be constantly on  ;)
Correct gra,i bought one for the vec for £2.50 IIRC,so not realyy worth making james. :y
maria
I think you guys are thinking of the EGR blanking plate, and not the one needed to go against the plenum?
hotel21
QuoteI think you guys are thinking of the EGR blanking plate, and not the one needed to go against the plenum?
You seem rather technically clued up tonight, Maria??   ;)
James - its a blanking plate that fits between teh EGR & plenum so that, on casual inspection, all appears normal.....
Apologies Broocie, I didn't see Maria was logged on  ::)
Thanks for the  info, this is exactly  what I need - I will get one in  :y
I think I know what you mean...
removing the egr setup, so you need to block off the pipework completely, and just leave an egr connected to keep ecu happy....
ie not just the standard blanking plate / coke car between egr and pipework....
QuoteI think I know what you mean...
That's the one - one to  go on the plenum...  :y
Thinking about it, you could fit the EGR as usual, without the wiggly pipe from the manifold, and all would probably still be happy....
hotel21
Why not just fit the blanking plate and keep the EGR and connections?  You trying for the 2.6/3.2 look?
QuoteYou trying for the 2.6/3.2 look?
nooo...as long as it runs, I can't see the engine from the drivers seat   :y
pedroMV6
I fitted an EGR blanking late to our Elite.
The car now uses more fuel (but the car is mainly used on short trips every day), is that normal?
maria
I wish I was  ;D ;D ;D
Martin_1962
James/Maria
I suggest you download another browser eg Chrome if you have Firefox, Firefox if you have MS IE.
Then use one each - no login problems then :y :y
