Wanted door strip
Started by Shackeng, 21 December 2009, 15:58:14
Shackeng
Hi All, I need a door buffer strip for the rear O/S door of my '99 CDX Estate (non-colour matched). The front edge has popped out and now catches the front door rear edge, so chrome strip is bent also.
Thanks.
[movedhere] Test Zone [move by] Jimbob.
Not sure the prefacelift strips transfer, so may be dealer time  :'(
Shackeng
thanks JB, I 'm sure a new one is not that dear.
Cheers :y
Welung666
They are changable, just get to your local motor factors for some trim tape.
You need a putty knife or similar and carefully push top and bottom to cut the existing trim tape, then slide the strip off the clips. Use a hairdryer to heat and peel the remainder off the paintwork. Re-fitting is the reverse but leave the backing on the trim tape till it's clipped in then peel it off so it sticks :y
I've only got a passenger side rear strip left here.
I'm guessing Welung666 has done it, and has more patience than me!
I went down the dealer route, around £55 + VAT for front door.
Jim
