automatic selector switch
Started by doug4293, 27 July 2010, 00:13:36
doug4293
couldnt post in the wanted section for some reason ? looking for a selector switch for a 3.0 v6 1996 elite auto. took my selector switch off and cleaned it but the white plastic (insides of the switch) is cracked beyond repair. or if anyone could tell me any other models that the switch could come off of and fit mine ? thanks
Signature deleted as it's too big.
Broomies Mate
#1
You have the 3.0, you have an AR35, so any V6 Petrol donor will do.
EDIT: Only the Diesel has the AR25, and even that might be the same.
Where are you?
#2
Selector switch the same across entire petrol range, unsure about diesel
Pitchfork
QuoteSelector switch the same across entire petrol range, unsure about diesel
It's the same
serek
#4
Quotecouldnt post in the wanted section for some reason ? looking for a selector switch for a 3.0 v6 1996 elite auto. took my selector switch off and cleaned it but the white plastic (insides of the switch) is cracked beyond repair. or if anyone could tell me any other models that the switch could come off of and fit mine ? thanks
got few selectors here 20 £ inc PP :y
doug4293
#5
serek thats great i have pm'd you, also just out of intrest, up to what year of cars will the switch still be the same for my 1996 ? i am in greenock scotland.
Quoteserek thats great i have pm'd you, also just out of intrest, up to what year of cars will the switch still be the same for my 1996 ? i am in greenock scotland.
From production start to production end
QuoteYou have the 3.0, you have an AR35, so any V6 Petrol donor will do.
Where are you?
Eh? 2.0 / 2.2 / 2.5V6 & 2.6V6 have AR25  :y
Pitchfork
They are all the same whether AR25 or AR35 regardless of fuel used to propel them
Broomies Mate
Where are you?
I need to clarify this for myself.
So only the 3.0 and 3.2 has the AR35?  I thought the 2.5 and 2.6 had it as well?
I know the silly 4pot engines had it, I was only talking about proper 6cylinder engines.
[movedhere] Omega General Help [move by] Jimbob.
in future, place wanted ad's in the test zone and I Will move them for you  :y
Where are you?
Less of it, we can't all go around towing a petrol tanker..... :D :D :D
david_omega
to my knowledge gained here and thru work on them,  the AR25 went on the 4 pots and the 2.6 v6,  the AR35 went on the 3.2
if a 3.2 packs up, the ar25 isnt strong enough for it, so only an ar35 will do.
however if you have a 2.2 or a 2.6 the ar35 from the larger 3.2 WILL work, just change the final drive donut (one nut bolts it to prop).
as for 3.0 autos,  i know a 3.0 auto box WILL work on a 3.2 but not entirely sure if a 3.2 AR35 will work on a 3.0 mv6 or not.
doesnt quite solve your query, but, for a fact the ar25 wasnt for a diesel, it went in the 2.2 2.6 also.
regards.
pedroMV6
Can I ask - I think my selector switch is on it's way out.
Symptoms:
Most times (since Tuesday), after 15-20 mins, the spanner light comes on, and the 'box stays in top gear.
It still revs up OK and can reach illegal speeds, so I don't think it's the limp home mode being employed
I can use the gears manually, but it clocks a bit when moving up from 1st to 2nd.
did it again coming home tonight, stopped for petrol (ten mins max) got back into the car and all is well again.
Twice, it's been fine, so I'm wondering if it's either the switch becoming worn inside, needs some white grease or simply a connection/wire with a break in it.
Car: 2001 MV6 2.6 estate.
Any ideas on the most likely cause?
