Pages: [1] 2 3  All   Go Down
Author Topic: Thanks to MDTM  (Read 5359 times)
Thanks to MDTM
« on: 04 August 2007, 21:16:37 »
For taking the time today, despite having (or at least should have had) a decent hangover, to do a couple of little jobs I was having trouble with on tractor.
Bumper stays on now :)
We are definately losing coolant somewhere, and its not appearing to leak :(
And the mod you made has improved economy significantly on way home (which I did in 1hr 5m, and yet average consumption was increasing all the time).
Thank you :y
Re: Thanks to MDTM
« Reply #1 on: 04 August 2007, 21:26:54 »
Coolant must be coming out of the exhaust then  ;D ;D
Matchless
  • Nottingham
    • A white van
Re: Thanks to MDTM
« Reply #2 on: 04 August 2007, 21:29:41 »
The mod you made has improved economy significantly on way home (which I did in 1hr 5m, and yet average consumption was increasing all the time).
He fitted the spare 1.3 Nova lump with twin choke??
Re: Thanks to MDTM
« Reply #3 on: 04 August 2007, 21:29:56 »
what about that slow drip we spotted in my garage? right at the back on the drivers side.....
Taxi_Driver
Re: Thanks to MDTM
« Reply #4 on: 04 August 2007, 21:44:48 »
 ;D ;D
Re: Thanks to MDTM
« Reply #5 on: 04 August 2007, 21:45:24 »
Your welcome as always.
And now there is a Tech 2 in Nottingham.......and I have to say that the upgrade to version 3 software on a facelift climate setup is VERY worthwhile!
Taxi_Driver
Re: Thanks to MDTM
« Reply #6 on: 04 August 2007, 21:47:46 »
Thank you :y
I have some extra long cable ties you could have used  :y ;D
Taxi_Driver
Re: Thanks to MDTM
« Reply #7 on: 04 August 2007, 21:51:12 »
Carnt remember if you checked the version on mine at the lakes?  :-[ I know you checked the g/b version....1a (10)
Would a 2003 have v3?  :-/
What difference does it make?
Re: Thanks to MDTM
« Reply #8 on: 04 August 2007, 21:54:18 »
0A TD (ie hex for 10) ;)
I'm sure MDTM will let you know v3 climate differences...
Re: Thanks to MDTM
« Reply #9 on: 04 August 2007, 21:56:19 »
And as well as the help, the kind hospitality, as ever when I visit, was appreciated....
Re: Thanks to MDTM
« Reply #10 on: 04 August 2007, 21:58:57 »
Haven't been able to get that again.  I wonder, if under the high pressure that builds up, if the rear coolant hose may weep?
Taxi_Driver
Re: Thanks to MDTM
« Reply #11 on: 04 August 2007, 22:04:59 »
Oooppsss so it is  :-[
I knew that really  ::)
Re: Thanks to MDTM
« Reply #12 on: 04 August 2007, 22:30:59 »
So...how did your lights compare then?
Re: Thanks to MDTM
« Reply #13 on: 04 August 2007, 22:34:20 »
Didn't compare, forgot :(
Re: Thanks to MDTM
« Reply #14 on: 05 August 2007, 09:38:32 »
The climate seems much more controlled and less intrusive, it runs at lower fan speeds for more of the time.
Pages: [1] 2 3  All   Go Up
