WANTED....estate rear centre console air vent !!
Started by bp_porcaro, 09 October 2010, 22:41:59
bp_porcaro
This item was missing when I bought the car and allthough it isn't an urgent item, I would like to fix it.
The car is a 2000 (facelift) 2.5td GLS with standard interia trim (dark plastics and blue type cloth seats)
If anyone has one I would gladly cover postage and a few beer tokens to get it  :)
vauxfan2k
if it helps a saloon one is the same, would imagine theres a few about on here with some.  ;)
bp_porcaro
cheers for the info, i just thought the estate might be a bit different, but never checked VX part numbers etc because it was a low priority job.
Lets hope someone has one then  ;)
joff
I'm thinking I have one in the garage will have a look today and get back to you. :y
bp_porcaro
 :y cheers.
Is the rear centre different to the front dash vent??
Just incase someone has one lying around that looks like the part I need, but may be out of the front dash.
I would not like to think I had one and then went to all the trouble of postage and waiting etc, for it to be the wrong part  :(
Cheers. BP
joff
I'm looking at the part I have the centre arm rest from a facelift estate dark grey and the vent above the cig lighter is that what you want. I take it they just pop out like the front vents do.
joff
I've taken them out and yes they just pop out like the fronts do. Is it just the two vent adjusters you want? or is it more? If it's just the adjusters you can have them for £5.00 +P+P.
bp_porcaro
reply to joff.....
Yes its just the pop-out bit I need.  I think it has a central adjuster (for open/close) and a vent either side of the wheel.
£5 +pp is ok.
Do you have a Paypal account?
mrjimbo
Hi joff, do you have the heated rear seat switches and panel thats just under the rear vents ?
joff
