Wanted: 2.5TD plastic manifold cover fasteners
Started by Radiomarko, 12 October 2010, 13:31:36
Radiomarko
Admin - please move to sale/wanted, Thank you.
Pre-facelift 2.5TD (BMW) rattling quickly traced to loose black plastic cover on top of engine, I think its called the "Manifold cover"?
There should be 3 black plastic screw fasteners, the one at the rear and one of the 2 at the front are missing causing it to flap about loudly ... actually really loud!. I don't have anything in the junk box that fits.
If you can provide, please PM me.
Payment available via paypal/bank transfer/cheque/postal order/coins sellotaped to an old Christmas card.
Thanks for reading  :)
I hate seagulls.
Welung666
The front 2 are plastic, the rear fastener is a 10mm nut and washer on a double ended bolt which in turn is bolted to the rocker cover. My rear fastener was missing when I got mine so I used a 2" M6 (10mm head) bolt up from below the hole with a washer either side and 2 threadlocked nuts tightened against each other. The just put a washer and nut on the remainder that was sticking through the hole in the cover. If that doesn't make sense then let me know and I'll do you a photo :y
Radiomarko
#3
Many thanks Welung666, I could not see anything in the rear deeper hole so assumed it was a screw.
Maybe the bolt has dropped through in the same way as yours had. I'll try and get a better look and sort something out.
I hate seagulls.
