Wanted - ABS ECU for 3.0 manual
Started by Dan-P, 10 October 2010, 14:33:22
Dan-P
I'm after an ABS ECU in good working order to fit a Y reg 3.0 manual facelift. Can pay by PayPal if easier.
Cheers,
Dan.
[movedhere] Test Zone [move by] Jimbob.
vauxfan2k
can you post up the numbers of your unit as it has to be the same type, there are a few variations.
cheers  ;)
Dan-P
Im not sure on the numbers, am i right in thinking these cannot be seen until the unit is removed? Or is it possible to view from anywhere while still fitted?
If not is there any way to work out which is the correct part number  :-/
sjc
#4
You need to remove the control unit box as the part number is underneath - clever, eh?
Only a few torx bolts though - remove the ones you can see holding the cover down, remove the cover, and pull off the wiring connectors and lastly, remove the torx screw marked "+".  Should now lift off.
BTW, I only have a very early one and that certainly won't be what your after.
scimmy_man
I have one off a 99 mv6 if any good?
still on the car so dont know the number.
