V6 Knock Sensor Needed
Started by JamesV6CDX, 04 April 2011, 14:33:07
After the 2-4-6 bank knock sensor.
It's for a 3.2 - though not sure if the later 3.0 part number will be the same?
Cheers
James
few types out there...looks like late 3.0, or 3.2 needed.
Search Results
Search results 5matches found for Control Valves & Units, Sensors & Flow Meters + Knock sensors
Omega       Part Number       Retail Price       Normal Trade       Trade Club
Knock sensors
2.0 16v       90411972       £35.85       £32.27       £27.96
2.0 8v       90510281       £36.70       £33.03       £28.62
2.5/3.0 to 08137540       90511177       £45.30       £40.77       £35.32
2.2       90530585       £36.70       £33.03       £28.62
2.5/2.6/3.0/3.2 from 08137541       90541521       £78.00       £70.32       £60.44
Ive got a 3.2 Im just going to start dismantling James.If you tell me what and where it is exactly I could take it off tomorrow. :y
QuoteIve got a 3.2 Im just going to start dismantling James.If you tell me what and where it is exactly I could take it off tomorrow. :y
Wire runs from the connector on the side of the cable tray above the passenger side cylinder head, down by the thermostat transfer pipe to a circular black device with a bolt through the middle, bolted to the side of the block about half way back. Look up forwards of the oil filter from underneath and you'll see it. :y
Cheers Kevin, if James wants it I should hopefully be able to whip it off for him. :y
