Pages: 1 2 3 4 5 [6] 7   Go Down
Author Topic: Jimbobs Coolant Leak  (Read 14366 times)
Re: Jimbobs Coolant Leak
« Reply #75 on: 07 August 2007, 10:06:43 »
More good news!
« Reply #76 on: 07 August 2007, 21:57:35 »
Ok, it all went back together pretty easily this eveninga dn was ready to run by 7.00pm.....so, start it up.....and there is a few drips which stop pretty quickly. Ok, well thats most likely to be some of teh coolant which will ahev been sat on the block.
Anyway, next there is a load of drips......bugger.....
Then realise that the aircon is on and its the condensate dripping!
So, all is good!
Jobs done this pm
Drain the oil and re-fill
Fit the B-bolt
Fit inlet
Git plenum
Connect up wiring
Connect up vac hoses
Replace hose.
Re-fill the coolant.
Engine vac is good (always a good test!)
So, its ready to go!
« Last Edit: 07 August 2007, 22:04:49 by Mark »
« Reply #77 on: 07 August 2007, 22:05:45 »
Ow yes, get a couple of big stainless steel jubilee clips to put round the base of the down pipe heat shields to stop them rattling!
« Reply #78 on: 07 August 2007, 22:08:01 »
And the coolant pipe was VERY broken.....
« Reply #79 on: 07 August 2007, 22:36:25 »
Brilliant!  So its done!
By any chance did the multirams spring into life with the fixed air leak?
A huge thanks for this!  :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y
So are you in tomorrow evening ?
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Matchless
  • Nottingham
    • A white van
« Reply #80 on: 07 August 2007, 23:34:28 »
Ive seen the multiram actuators working and also measured the idle vacuum as being higher than on my carefully rebuilt motor but at least my exhaust heatshields dont rattle.  ;)
« Reply #81 on: 08 August 2007, 06:27:56 »
Cool, (just like the aircon ;) ) Cheers
Did the tech2 find why the aux coolant pump was on?
« Reply #82 on: 08 August 2007, 08:03:48 »
Your varient code in the climate panel.....it thought it didn't have an aux coolant pump.
I am around this evening and tomorrow evening.
« Reply #83 on: 08 August 2007, 08:07:47 »
Cracking, I'll organise some babysitters, and hopefully see you later.
Suspect be nearer to 9pm tonight if thats ok?
Glad to have had THE expert do my car, you've spotted things that must have been wrong for a very long time  :y
« Reply #84 on: 08 August 2007, 08:14:13 »
Thats fine.
« Reply #85 on: 09 August 2007, 09:38:16 »
[size=14]Conclusion[/size]
Water Leak
This was the result of a number of things:
1) The main stat bridge pipe to radiator hose had a split in it, this had been bodged with a jubilee clip and was not working to well
2) The dowty washers used on the coolant bridge were of the wrong type and size, this resulted in poor sealing and a fair bit of coolant loss.
3) The oil cooler plate had been sealed using camcover sealent and not the correct grey flange sealent, this wasn't leaking but, would not have lasted. The cooler pipes were straightened when re-fitted.
In addition:
a) All pipes were removed and checked on the bench
b) The main coolant pipe (runs around the 1-3-5 head) was removed, cleaned and the seal replaced.
c) The thermostat was removed, checked and sealed to the block on re-fitting using the grey sealent.
d) The stat bridge pipe had new seals fitted.
Following re-assembly, all was seen to be good.
Air leaks/Multiram
A number of small air leaks were found and addressed
a) The breather bridge to plenum seal was replaced, the old one was pretty mangled and resulted in the bridge piece sitting proud of the plenum.
b) The main brake servo pipe had damage which had been taped up but, becase the pipe had been re-fiited so it could rub on the aircon pipe, it wore through again. This was repaired using a plastic glue with self amalgimating tape over the top and black tape to finish, the pipe was re-fitted ensuring that it was not touching the aircon pipe.
c) The vaccum tank was checked and the one way valve internal to the unit had failed. A tropical fish tank air valve was fitted to remedy the problem.
All vac hoses were fitted and routed where they should be so as not to result in any future damage.
Misc items
Crank sensor cabling was routed in the modified route via the passenger side inner wing. This should result in the part lasting much longer as it is less exposed to heat and any future swap put is MUCH easier.
Windscreen washers were fixed, the low pressure on these was due to the washer pipe being trapped under the ECU box.
Instrument panel software was corrected, no varient coding was programmed into the unit.
Climate panel coding was in-correct, the panel was not setup with an aux coolant pump and hence it was permanently running it!
Crack of doom was fixed by tightening up the door check strap bolt!
Test drive
The car drove very well with no strange knocks or clonks, engine is responsive and handling is good. MPG seems pretty spot on and engine vac is excellent sudgesting the mechanicals are in good condition. Engine internals are nice and clean
The suicidle sparrow collected in the front grill during the test drive was removed on return, how does a bird traveling at a few mph into a car traveling at 60...ish mph end up embeded into the grill arse first!
Steve W
  • Somerset
« Reply #86 on: 09 August 2007, 18:43:10 »
Glad its sorted and is becoming the car it always had the potential to be. :)
« Reply #87 on: 09 August 2007, 22:17:13 »
ROFL!  ;D
I guess he was trying in vain to escape impending doom. Or he had turned inside out.
Doesn't beat my Pheasant that wedged itself between the wishbones on the Westie and was gradually being sauteed (and plucked pretty well, too) on the brake disk. I often wonder where its' head ended up. I suspect that it was above the top wishbone at impact whereas the rest of its' body was below  :( It was a pleasant parting gesture for him to arrange to completely miss my braided brake hose though.
« Reply #88 on: 09 August 2007, 22:18:39 »
I decapitated a hen once as the stupid thing ran out in from of my Escort van going flat out. Took it clean off.
« Reply #89 on: 10 August 2007, 07:56:49 »
Cheers all, my best decapitation was a pheasant....no matter how much I swerved, he mirrored my movements
THWACK, cloud of feathers, car behind got covered in blood and guts!
Car running like a dream, Big jubilee clips on order, will refit that heat shield thingy when I fit those.
Next door neighbour (loves cars) came out just as I was pulling in last night, "came to see what that lovely sounding car was, ITS YOURS, sounded great before, sounds even better now"
Tis nice to drive again, so much smoother than it was :)
needs about 2cm coolant top up tonight, hope its just settlement and air escape.
No smoke this morning either.  (if I hadnt opened the bonnet, wouldnt have seen it yesterday mind)
Pages: 1 2 3 4 5 [6] 7   Go Up
