Wanted Philips DC012 Autochanger.
Started by flymofred, 28 April 2011, 08:35:21
flymofred
Having had mine declared terminal I need a new(2nd hand) one. I appreciate this is in the wrong section, so if it could be moved rather than deleted I would be grateful  Cheers martinH
[movedhere] Omega Electrical and Audio Help [move by] Jimbob.
sjc
I've got one here but the laser is poor (skips a lot etc.).  Works ok with certain CDs.
Yours for the postage.
flymofred
thanks for that, but mine was doing that before it gave up. I don't think I could stand that again. I guess I'll have get my cassette deck out the loft and start knocking out tapes again.
Cheers martinH
sjc
Or, get a Blaupunkt changer from a newer model - not sure if you'd need the head unit to go with it or not.
If I get a chance, I'll try an older head unit with the Blaupunkt changer and see if it works.  It's the same wiring so it might.
QuoteOr, get a Blaupunkt changer from a newer model - not sure if you'd need the head unit to go with it or not.
Doubt it. There are at least 3 CD2 changers that are not compatible with each other despite all having the same name.
david036
I think I've still got one of these, will have a check when I get to the unit later on
TOYOTA AYGO, CITROEN C1 ENGINE PARTS FOR SALE.  ENGINES HAVE LESS THAN 10MILES ON THEM.  CATS FOR SALE AS WELL.  HUGE SAVINGS ON DEALER PRICES
