Auxiliary coolant pump.
Started by Brikhead, 27 June 2011, 10:45:20
Brikhead
removed from this vehicle...
http://www.omegaowners.com/forum/YaBB.pl?num=1307653505
Connects between heater matrix and h.b.v.
Complete with bracket and coolant hoses.
£15 collected, £25 Pay-Pal and recorded post.
alank46
Yes please, especially if you can supply the electric plug with a bit of cable attached.  What is your paypal address.
Alan
Brikhead
QuoteYes please, especially if you can supply the electric plug with a bit of cable attached.  What is your paypal address.
Alan
I'll have a look for the wiring connector, it should still be knocking about under the bonnet somewhere as it's not part of the main engine loom... I'll let you know.
If you p.m. me your e-mail address then I can send out an invoice via Pay-Pal, I don't mind paying the fees and you get 'buyer protection'.
Cheers,
Rich.
Brikhead
I managed to find the connector and a bit of loom, around 8 foot!
Do all Omega's have another aux. coolant pump, mounted to the radiator? You can have that too, if needed. Let me know.
Remember, for the ECU to control this, the Climate ECU will need reprogramming with tech2 (If you dont currently have the AUX pump)
alank46
Thanks for the heads up, but I am going to control it manually.
Alan
QuoteRemember, for the ECU to control this, the Climate ECU will need reprogramming with tech2 (If you dont currently have the AUX pump)
