Urgently Wanted! Rear Lap Belt from an Estate.
Started by P6UL K, 18 July 2011, 13:44:35
P6UL K
Hi guys,
I urgently need the rear lap belt and the buckle that are attached together via the metal clip that bolts to the under seat part of the chassis that go in an Estate.
I have both side seat belts for passengers, but only a double belt buckle on the passenger side.  Need the drivers side buckle so i can connect the drivers side rear belt into it and the lap belt too.
This is all i have:
But need this to pass the MOT:
Cheers guys, urgently needed!!  Monies waiting!!
ill move, but not many of those about...most omegas had 3 x 3 point belts.
whats your interior?
you may have more luck getting a whole new rear seat!
P6UL K
#3
Quoteill move, but not many of those about...most omegas had 3 x 3 point belts.
Its an estate mate, don't recall it ever having a normal seat belt in the middle?
I have the Recaro interior, as found in the caravans from europe...
You can see in these two pictures what's missing...
Yup, Ive had 3 estates...and seen plenty more - lap belts are rare, most are proper belts  :y
P6UL K
Pictures added to help explain....
Thats a very unusual / rare interior.
looking in EPC, I think you need part 90379464
omegod
QuoteI assume you've checked under the seat?
I was thinking the very same!
P6UL K
Quotehows ya german?
http://cgi.ebay.de/Opel-Omega-B-Kombi-Gurthinten-Mitte-90379464-/230642962965
Thanks Jim, i'll get on it - but i need it ideally within the 10 workings days i'm allowed to sort failed items out.
P6UL K
Is the pope catholic?  Of course i have, first thing i did do!  :y
could be worth a call to your dealer - could be easy and cheap new  :-/
or message the German, see if you can courier it
P6UL K
Quotecould be worth a call to your dealer - could be easy and cheap new  :-/
£76 + vat from the stealer's!!!
Do you think this would be the same?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=110698610030&ssPageName=STRK:MEWAX:IT
