looking for a Ignition Lock Cylinder with key
Started by AjOmega, 28 July 2011, 18:26:47
AjOmega
Hey im looking for an ignition lock cylinder with a key for a cadillac catera from a donor someone that doesn't have use for it. This really would help me out been looking for one over a month now. Thank You :) :)
[movedhere] Omega Electrical and Audio Help [move by] Jimbob.
QuoteHey im looking for an ignition lock cylinder with a key for a cadillac catera from a donor someone that doesn't have use for it. This really would help me out been looking for one over a month now. Thank You :) :)
Are they the same as the Omega :question
AjOmega
yes i believe so there just a different name.
#4
Ignition switch assembly minus connector as in this guide.
http://www.omegaowners.com/forum/YaBB.pl?num=1225659626
Or just the barrell as in this
http://www.omegaowners.com/forum/YaBB.pl?num=1225657771
AjOmega
That was the removal of the cylinder i did that already. i Just need a cylinder from somebody thats not using it and can just donate it to me. :)
QuoteThat was the removal of the cylinder i did that already. i Just need a cylinder from somebody thats not using it and can just donate it to me. :)
Does that mean the same in California as it does here, I wonder ? ::)
AjOmega
twiglet
QuoteNormally, free of charge. ;)
I suspect it does Albs. Don't forget it's a charity we are running here!  ::) :-X
;D ;D ::)
Brikhead
I have an ignition barrel, door lock and 1 key available for £25, I have no idea what the postage charge would be but it would need to be paid for in addition to the cost of the parts...
AjOmega
ill have to check and see about the postage.. skip the last message. :)
FWIW I just sent a package of (probably) similar size and weight to the US using the bog standard Royal Snail service and it was £3.50. Got there in 4 days too. :y
