Author Topic: Will Mrs TheBoy make it home  (Read 3896 times)
« on: 02 September 2007, 20:19:03 »
As most will know, I sent her off to Great Yarmouth in the MV6 this weekend.  Don't tell her, but I knew the battery was suspect, so I packed the jump leads just in case...
Every time she rang whilst I was at Wales meet, I always wondered if it was to say battery flat.  The battery has held up well, but she rang this morning to say the EML was on, and she had a Coolant Level warning on the dash  :o
Crazydad
  • Germany
    • 2.5 V6 facelift
Re: Will Mrs TheBoy make it home
« Reply #1 on: 02 September 2007, 20:20:53 »
Serves you right for being such an Evil Person ::) ::)
and i thought that you were a man of Honour :D
Martin_1962
« Reply #2 on: 02 September 2007, 20:22:20 »
Oh dear better - better take tech2 for a seaside break :(
« Reply #3 on: 02 September 2007, 20:23:00 »
That conversation did sound worrying, just like the expression on your face.
Have you had her check the coolant?
Im thinking you and tunnie will be doing head gaskets together soon ;)
you should at least have plenty of coolant in  stock for the tractor ;)
miggy
« Reply #4 on: 02 September 2007, 20:23:58 »
You deserve a load of tonge pie when she gets in. Did she know the full issue with the baterry before she left. :question
 ;D ;D ;D
STMO123
« Reply #5 on: 02 September 2007, 20:24:37 »
Coolant level message is probably the sensor, I hope :o
miggy
« Reply #6 on: 02 September 2007, 20:26:40 »
Cooked if not
« Last Edit: 02 September 2007, 20:55:17 by miggy »
« Reply #7 on: 02 September 2007, 20:26:54 »
Yes, the coolant is a little low.
Plenty of coolant between Tunnie and I ;)
Taxi_Driver
« Reply #8 on: 02 September 2007, 20:27:54 »
Tell her she's broken it......and its gonna cost her ;D
Low coolant.....no probs.....unless it was on the max mark before she set out.....mine leaks a tad too
EML.... :-/ She broke it  :y
« Reply #9 on: 02 September 2007, 20:31:12 »
I guess I should have checked the coolant level before I sent her out ::)
Martin_1962
« Reply #10 on: 02 September 2007, 20:40:23 »
Sorry - it had to be done.
I hope it is all OK, has she peeped under the bonnet yet?
Can she do a paperclip test?
« Reply #11 on: 02 September 2007, 20:44:09 »
got a big drum of coolant here, although I need most of it!
dads one needs coolant after the HG, mine needs a change too, project Elite will need one too after the oil cooler.....
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #12 on: 02 September 2007, 20:54:05 »
she`ll be fine  ;) how far has she still to travel ?  :-/
« Reply #13 on: 02 September 2007, 22:07:40 »
She made it home about an hour ago :y
Haven't been out to check, too busy with a chicken madras...
Rather worryingly, she has said she put a bit of bumper trim in the boot  :o
STMO123
« Reply #14 on: 02 September 2007, 22:08:56 »
Good to the first bit
 ;D ;D ;D to the second
