Author Topic: Coolant Low  (Read 2111 times)
Coolant Low
« on: 06 November 2006, 08:01:27 »
MID is saying coolant low, but it isnt :(
This is on a 2000 2.2 Facelift
Ive opened the tank and there is a little black bit at the bottom which I poked with a stick, looked to be a float type thing cos it raised up a bit.
Coolant low warning still there though :(
Any ideas?
is it new sensor time? can it be taken off and cleaned? or I disconnect it and short the connection?
Re: Coolant Low
« Reply #1 on: 06 November 2006, 08:43:51 »
Check float is free to move easily, and also clean connections underneath.
I believe to replace, you have to do entire bottle....
Re: Coolant Low
« Reply #2 on: 06 November 2006, 08:54:29 »
Cheers, these things are never easy are they!
Will have a play when I get home.
markey mark
  • SLady bitshorpe north lincs
Re: Coolant Low
« Reply #3 on: 06 November 2006, 09:34:56 »
take it off and run clean water threw it or pop it in dishwasher !!  :y
x25xe
  • Hayes, Middlesex
  • Avater removed due to size
Re: Coolant Low
« Reply #4 on: 06 November 2006, 11:03:10 »
I had this problem and can confirm that the only real way of sorting a float switch issue is a new bottle.  It is very easy to replace, it clips in with a metal clip on the side that faces the front wing and there is a lug that is on the bottom of the bottle.  Disconnect the wiring (there is enough slack in the loom) reconnect to the new bottle and then line the lug up on the new bottle and then clip it in.
A new bottle also looks very nice in the engine bay, particularly if you replace the antifreze / coolant mixture with the long life red!
1998 2.5 V6 Omega CDX, Leather and Electric Pack!
Re: Coolant Low
« Reply #5 on: 06 November 2006, 11:44:23 »
May have to go that route :( Anyone got a part number / price for a new tank with sensor?
x25xe
  • Hayes, Middlesex
Re: Coolant Low
« Reply #6 on: 06 November 2006, 14:37:46 »
I got mine from Autovaux.  I cannot remember the part number I am afraid  :-[ but the price was, I think, around £25 - 30.  Vaux wanted nearer £40!  Give them a rin their number is on the website, http://www.autovaux.co.uk/LoadPortal.aspx?tabid=4 - this will take you straight to the "contact us" page.  Don't try and order on line though, the web site is not that good.
Hope this helps and good luck!
theolodian
  • I need a new avatar.
Re: Coolant Low
« Reply #7 on: 06 November 2006, 14:46:43 »
Or you can do what I do and just ignore it.  If it was the only warning I was getting then I might feel differently  ;)
Re: Coolant Low
« Reply #8 on: 06 November 2006, 14:59:44 »
Its the wife's and its driving her mad.
Just replaced front brake pads and sensors as well, MID still complaining about those as well.
She is getting tempted to put gaffer tape over the display.
« Last Edit: 06 November 2006, 15:02:38 by jimbob »
Page created in 0.009 seconds with 16 queries.
