Sticky question
Started by Tony H, 30 November 2006, 21:51:21
Tony H
Good evening everybody out there, can anyone advise me on the best glue to use on the rear light unit ? I have broken a small piece off mine. thanks in advance :y
rogerreno
I always find that genuine Loctite Superglue sticks almost anything and if you're sparing with it you probably won't see the join!!  :y
I Have tried various cheap 'superglue's' in the past and have found them to be a waste of money...this is all IMO though  ;)
Elwood: It's a 106 miles to Chicago. We got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Jake: Hit it!  8-)
Eliteman Steve
QuoteI always find that genuine Loctite Superglue sticks almost anything and if you're sparing with it you probably won't see the join!!  :y
Superglue sounds like a good suggestion :y
nixoro
Would it not be better to get a cheap replacement off good old Ebay.
Glue is ok as a temporary fix but I always find it never lasts.
Good luck with replacing or glueing and if glueing be careful you dont glue your hands to it, could be very  :-[
Just my tuppence worth :y
Most superglue's dont like water, so not much good on cars.
I broke a corner of the lens of one on the mazda (you have to yank it off the car to change the bulb!)
I used araldyte super glue, this was over 6 months ago, still stuck firm.
Markjay
#5
I use a small amount of Loctite Superglue to position the broken bit in place, then a thick layer of clear dual-pack epoxy resin (the twin-syringe one) to give it strength and water-seal it.
Alas, no more Omegas....
