Author Topic: Water in footwell  (Read 1745 times)
Water in footwell
« on: 07 December 2006, 19:23:49 »
I'm after some opinions. I'm thinking of buying an Elite, it has a known intermittent coolant leak, and the owner has discovered some water in the passenger foot well.
What's the likely cause? Heater Matrix? If so, has anyone ever done one, and what are they like?
Any other causes of water in footwell, eg scuttle drain from memory? Cheers...
The Barge Captain
Re: Water in footwell
« Reply #1 on: 07 December 2006, 19:30:29 »
I'd go with scuttle drain and a HBV problem.
« Reply #2 on: 07 December 2006, 19:31:28 »
I understand the logic of scuttle drain, but a HBV wouldn't cause a leak into the car, no?
The Barge Captain
« Reply #3 on: 07 December 2006, 19:33:53 »
No but might explain intermittant coolant loss.  Two seperate issues.
« Reply #4 on: 07 December 2006, 19:35:44 »
If its a knackered heater matrix, its a big job - a lot has to be stripped out to get to it...
Boiler Man
  • Sale, Manchester
« Reply #5 on: 08 December 2006, 00:51:56 »
Like The Barge Captain says, it could be two seperate faults,
The leaking HBV can be a tricky one to catch, as in my experience it can only leak when the system is cold and then again the other way around, only when hot, when pressurised..
As for the scuttle drain. Try pooring water into the area were the pollen filter is located, once you have removed the grill.  But not on the filter, Making sure that you miss it and direct it away past the filter into the gap toward the front of the car well away from it. If it fills up, then that is a seperate issue. Your drain is blocked.
Then look again at the HBV
Other members correct me if I have discibed this badly please.
« Last Edit: 08 December 2006, 01:03:34 by Boiler_Man »
Omega 2.0 DTI GLS Estate 99 Gold & Omega 2.2 DTI CDX Estate 03 Silver. Just need a Bronze one now for the full set.
