Author Topic: Intermittant ABS TC and speedo fault?  (Read 16874 times)
« on: 23 November 2006, 15:59:57 »
Well guys the ABS and TC light came on and about the same time the speedo stopped working got a about 2 miles down the road and the lights went off and speedo came back to life then lights flickered on then went off I'm guessing a dirty sensor do you know where they are located or any other ideas of what this fault could be? facelift 3.0MV6
cheers Liam :y
Re: Intermittant ABS TC and speedo fault?
« Reply #1 on: 23 November 2006, 16:22:49 »
Well if its speedo related then its most likely one of the rear sensors.....check also the plug on the main ABS ecu (end of the modulator on the passenger side of the engine bay)
« Reply #2 on: 23 November 2006, 16:29:35 »
Ok m8 will have a look cheers  :y
« Reply #3 on: 23 November 2006, 16:48:31 »
cheers Liam :y
Sorry to be possible bearer of bad news, but every one I've seen with this fault has needed a new ABS ECU :(
Not a mini facelift or very early facelift by any chance?
« Reply #4 on: 23 November 2006, 17:00:29 »
cheers Liam :y
Early facelift how much are these :'(
« Reply #5 on: 23 November 2006, 17:02:03 »
do checks as mark says, as you really, really, really do not want to buy one of these....
« Reply #6 on: 23 November 2006, 17:03:39 »
Take that as a lot of money then >:(
« Reply #7 on: 23 November 2006, 17:04:27 »
If you fit it yourself, you may get change out of a grand.
« Reply #8 on: 23 November 2006, 17:06:43 »
F*****G hell is all i can say to that >:(
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #9 on: 23 November 2006, 17:08:35 »
B****y Hell.... :o
I like red cars
« Reply #10 on: 23 November 2006, 17:11:10 »
I tell u i really hope its one of the sensors  cause i can do without that just before christmas
« Reply #11 on: 23 November 2006, 17:15:23 »
I've heard of a company selling recon ones for a couple of hundred, but they tend to have faults on as well :(
« Reply #12 on: 23 November 2006, 17:17:09 »
Also, if you do have to replace, ensure you get right one - you'll probably need ident code off old one.
Steve W
  • Somerset
« Reply #13 on: 23 November 2006, 17:26:40 »
The unit itself is around £300 + VAT, and you would be looking at least the same again to fit it.
There is a "how to" in the maintenance guides on here.
Deffo not a fun job though.
« Reply #14 on: 23 November 2006, 17:29:49 »
When yours failed, was it on your mini facelift?
Pages: [1] 2 3 4  All   Go Up
