Brake Pedal Creep
Started by Idris, 15 December 2006, 18:58:25
nixoro
Am I right to think the car is a manual now having had a similar issue with my dads 2.0 where the brake pedal would travel right to the floor with hardly any effect.
Basically the car had new brake pipes fitted and the guy who fitted them only bled the brake system at the calipers but not the clutch and topped the reservoir up and so as the two are on the same system I thought to bleed the clutch and now the brake pedal is much firmer and even the clutch is working much better, when bleeding a load of air came out which I can only assume was the problem.
Not sure this is any help to you but thought it maybe something to look at.
My next course of action would be to call Vauxhall customer services......they are very helpful people.
sounds2k
hmmm ... just an idea ... none of the calipers are sticking are they, especially the rear ones? I seem to remember the brake pedal on my old miggy being a bit odd, one of the rear calipers was seized ... possibly worth checking?
Idris
QuoteI have tested mine a few times since you first posted.
I have NO creep on my 1998 MV6 Omega.
Thanks, keeping count
Idris
my email address is irfrancis@onetel.com
Markjay
#49
Idris
my email address is *****@onetel.com
Idris,
There is something called bots which is basically automated software routines that scan websites for email addresses and automatically compile spam email lists – so unless you are particularly interested in various enhancement medication or fake Rolex then it is best if you send your private email address by Personal Message (PM), and remove it from the post.
Alas, no more Omegas....
Idris
replies to various - thanks to all
My Omega is an auto, so clutch issues do not apply.
My email address is everywhere anyway, so a few more won't make much difference!
Idris
Idris
First, for anyone not wishing the read the whole of this:
Can anyone recommend a thorought competent brake specialist, preferably somewhere from SW London the Hampshire, or otherwise anywhere in SE England?
Does anyone know a garage or brake specialist who use - or the supplier of - Tech1 (Tec1?) a system which electronically opens  and closes the ABS valves while pressure flushing the brake fluid? This offers the lowest cost solution if my diagnosis is correct.
Current symptoms, after not using the (petrol, ABS) Omega for more than 2 weeks over Christmas:
Brake pedal "creep" is significantly worse than before, taking no more than 4 or 5 seconds at typical brake pedal pressure for the pedal to creep down to the end of available travel - or close to the end.
Releasing the pedal and immediately re-applying it results in the original travel and then renewed creep, ie the pedal "pumps up."
Checking on an empty motorway in the early hours, braking reasonably from 70mph, I can now confirm that the pedal creep DOES happen when the car is moving - not just when stopped (one of the excuses for why this symptom"does not matter")
The pedal creep is also evident with the engine stopped and ignition off, though because there is no boosted pressure due to the servo, it is less obvious).
(As before, there is no fluid loss and the master cylinder has been changed to no effect)
The Vauxhall service manager, trying to be helpful, asked me to get an independent report confirming that these are fault symptoms, so that he can show it to the Network Q people who deny that there is and get them to authorise him to fix it.
I asked the local MOT garage who did the recent MOT to check the brake creep - no problem, they say! I pointed out that the pedal virtually reaches the end of the available travel, ie the stroke of the master cylinder - and the chap said "it doesn't - not quite!"
One car inspection company, which was hesitant on the phone about whether these are fault symptoms or not, wanted £150 to come to check it out - cash I would of course lose if they said that there is no fault. Today I went to 4 "brake specialists". The first two had side street garages rather smaller than mine at home and I could not sensibly expect Vauxhall to accept their opinion in preference to their own. At the third, the moment I mentioned "brake problems" he said that I should come back in the morning, as they would not have the spares until then. Quite how he knew that he did not have the spares in stock, but would have in the morning, before I had told him the nature of the problem I do not know - but in the time-honoured phrase, I made my excuses and left.
The 4th, Kwik-Fit in Isleworth, agreed that the symptoms were odd but were not prepared to say outright that there was a defect. So overall, I am dubious about being able to get an enforceable opinion that there is a fault so that Vauxhall give in, and for that reason am not inclined to give the car back and sue for it to be fixed or replaced.
Vauxhall's view is that this is "normal" - indeed they told me they have the same symptoms on a new Vectra in the whowroom! They also say that it only happens when the wheels are not turning, and that the ABS allows the pedal to creep down in this way.
Can anyone fault any of the following logic of why this is GARBAGE?
(1) A few members of the Omega owners web group have confirmed to me that they have similar symptoms - others that they do not, after checking in the light of my comments. So how can this be "normal"?
(2) The car did not have this symptom when I bought it a year ago - or I would not have bought it. A month ago the symptom was only just noticeable, with high pedal pressure. Now it is obvious with modest pressure. So how can it be "normal"?
(3) For anyone used to non -ABS cars, pedal creep is an unmistakable sign of a fluid leak - so if this ABS system was designed to do this, the handbook would surely have pointed out that the symptom is "normal" - but it does not do so.
(4) Nothing I have found on any web site, for MOT testers, VOSA etc, nor any MOT tester seems to have any official circular stating that this is not a fault symptom on these cars.
5/ If pedal creep WERE normal - how would a driver know that a leak was developing elsewhere - eg in a master cylinder seal - before it became dangerous?
6/ As I understand it, ABS valves, being electrically operated, are either open or closed - no proportional opening is possible. When triggered they chatter open and closed at 30 cycles per second, making that rattling sound and pulsing feel on the brake pedal. As I understand it the 4 valves - one for each wheel - are the only designed-in way that fluid can be released deliberately.  All those being the case, how could it be possible for a "normal" valves to allow a SLOW leak? If they are closed, they allow no leak, if they are open they allow a major leak, and it is not possible that they could cause a slow leak by chattering, as they are designed to do, because (a) the chattering would be clearly audible and (b) easty to feel on the brake pedal.
7/ I refuse to believe that anyone would design a system that would allow the pedal to take up all or almost all of its available travel
8/ If the system WERE designed to allow the pedal to creep down almost but not quite to the end of its travel, the system would need to know when the pedal/master cylinder had reached that point - for example. by leaking the fluid through a hole which gets covered up as the pedal reaches that point. Unless and until someone confirms that this is what happens, I refuse to believe it.
As things stand therefore I plan to find someone who can use the Tech1 or similar system to try to clear the fault, and if that fails get the ABS valve block replaced myself, and when I can then show that the symptom has been eliminated, ask Network Q to pay
see also brief next post
Idris
PS
BUT THERE'S MORE!
When I decided - after being told that the brakes are "normal" to drive slowly and carefully to get other opinions, I decided to test out the handbrake - only to find that it has virtually NO effect! It feels normal, but has no apparent effect on speed, except at very slow speeds indeed when it can just be felt. I took it back to the same MOT garage that passed it a month ago and they put it on their rolling road - and told me that it achieved DOUBLE the minimum of 16% efficiency ie 0.16g, at 0.33g!
I have many times driven my old cars with MOT testers in the passenger seat, monitoring the old style Tapley brake meter - still used for vehicles which cannot be used on rolling roads. I know perfectly well what 0.33g feels like - quite strong braking, but of course well short of a panic stop at close to 1g that can be achieved in optimal conditions. There seems to be no resemblance at all between the barely noticeable braking the handbrake gives on the road and the rolling road reading,
Any help and advice appreciated.
Idris
sounds2k
sounds like the rear brakes need servicing ... the sticking caliper problem on my old omega keeps coming to mind when reading this!!
have a look at the guide here
familyman
Just a note. handbrake percentage has dropped from older cars to 16% due to split circuit braking. VOSA feel that the chances of both circuits failing on a modern car is very very small
point being that handbrakes don't have to stop the car any more just basically hold it on an incline to stop it rolling once the car has come to a stop.
Not to say that your handbrake shouldn't be able to stop but i would expect to see at least 30% of weight of car as your efficeincy.
What i've found normally gives a poor handbrake is continual adjustment of the cable to reduce slack.
Correct proceedure with drum style handbrake is to fully slacken cable/s adjust shoes up to just touch drum (don't rely on self adjusters working) back of a 1/4 of a turn then adjust cable/s to achieve correct h/brake cable. On rear disc models with h/brake shoes inside the drum of the disc relatively easy through hole in disc(with wheel removed!) with drum brake rears bit of a pain to keep taking drum off and on but a good time to check shoes and lip on drum for wear. not sure on 'meega's if there all disc any way.  :)
You came in that, your braver than i thought
Can I sudgest that you take the car to another Vauxhall masterfit outfit and ask for a free brake check (most do this) as the pedal is sinking to the floor, dont mention network Q warranty or anything and wait for the free report.....
Then hit them with the Network Q warranty.....
Incidentally, if you need to get the pump operated in the ABS unit, for you're car it is a Tech2. Tech1 is for pre 1997 cars...
Idris
Thanks for various replies.
Dealer just fitted new rear pads - for no reason I can think of. I would tend to think they would have seen any sticking problem. Also, unable to see how sticking pads could cause my symptoms
Since writing have found more info, Tech 2 is the machine for my 2001 car. I will now ask dealer whether they have changed the fluid, and/or used Tech 2. If not will ask them to do it.
Thanks for free brake check info - good idea, will do if Tech 2 does not solve it
Re handbrake - what astonishes me is that a 30% efficiency reading on the rolling road, confirmed as meaning brake effect equivalent to 30% of weight, should mean 0.3g deacceleration. I have driven my old cars to test foot and hand brakes on Tapley meter, and I know more or less what 0.3g feels like - eg it corresponds to having to lean forward about 30 degrees to keep balance - but what the Omega provides on the road is barely noticeable at all. I intend to borrow a Tapley meter and see what thehandbrake is REALLY like.
30% should mean that handbrake would hold on a 1 in 3 hill - I doubt whether this would hold on a 1 in 20 hill, it certainly does not hold on a typical motorway slip road!
Idris
Cheers
Martin_1962
The hand brakes are not brilliant - they pass MOTs and that is good enough.
I prefer what they have to the alternatives, such as handbrake mechanisms within the calipers - they tend to leak, I aquired some Chrysler 180 rear calipers once but could not get the seal kit (common Sunbeam conversion) they were leaking around the hand brake mechanism. And the other alternative of rear drums :o
The handbrake works well when correctly set.....which seems to rarely happen, I am yet to get an Omega where it works correctly !
