Author Topic: Idle Air Control needs cleaning every 2-3 months  (Read 2992 times)
suavegarve
  • Fleet, Hampshire
« on: 16 February 2007, 16:34:18 »
Anyone got any advice on why my IAC is playing up every 2-3 months. Every time I clean it thoroughly, even the little hole that some people miss. I've been to the scrappy and got another IAC but still have the same problem.
Once cleaned, revs are fine, but give it a couple of months and they are up and down like a yo-yo.
Any help greatly appretiated.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Idle Air Control needs cleaning every 2-3 mont
« Reply #1 on: 16 February 2007, 16:37:43 »
Have you changed the fuel filter lately?
I like red cars
suavegarve
  • Fleet, Hampshire
« Reply #2 on: 16 February 2007, 16:40:22 »
Nope. I have one in the garage, just never got round to fitting it.
Is that likely to make a difference.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #3 on: 16 February 2007, 16:46:19 »
Not sure, but it can't do any harm to try it.
If you've already got one, it will eliminate that problem.
« Last Edit: 16 February 2007, 16:47:23 by Auto_Addict »
I like red cars
« Reply #4 on: 16 February 2007, 19:04:54 »
Do you have a flame trap in the camcover to block breather pipe at the rear right of the engine, is this breather also nice and clean including the metal section that goes to the block.
Matchless
  • Nottingham
    • A white van
« Reply #5 on: 17 February 2007, 14:10:00 »
The flame trap mark refers to is a black plastic box connected to the breather at back right of camcover, if you dont have one there will just be a rubber elbow pipe here.
It sounds to me like there is a breather problem. Get a new Oil Separator (aka flame trap) from Vx (£7 to £10) also get a new gasket for the steel breather pipe to block joint.
Remove the steel pipe, two bolts at bottom; clean out throughly; flakes of dried oil muck from here get into the idle valve. refit pipe with new oil separator. You cut the old rubber elbow pipe to make the joining pieces to the breather pipe and cam cover if one wasnt fitted previously.
Pull the small breather pipe off cam cover (front left) you should be able to blow / suck through this pipe. If not follow it to throttle body or manifold (depends on year) and clean out the hole (throttle body) or banjo spigot (manifold).
Check that the pipe spigot into the camcover is free / not blocked. clean out with a drill bit in finger tips. 3 mm?
Remove large breather pipe completely and clean out with kitchen paper & paraffin etc. Check that it has not delaminated inside.
Remove and flush out the ICV with carb cleaner then add a drop or two of light oil.
Clean the throttle body well, make sure that the edges of the throttle disc and the bore of the body are spotless. If very mucky remove throttle body to clean properly....need new gasket.
Hopefully this will cure it, each year afterwards just remove IAC and leave to soak while you drain oil and change filter then refit with new gasket.
If problem persists and there is lots of oil in the intake then its possible that there is some wear in No1 bore and a damaged piston ring but this only affects earlier engines with +150k.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #6 on: 17 February 2007, 15:20:22 »
Don't know if you can still get flame traps, I had one on order for over 3 months, gave up in the end.
Mark tried to get me one as well, to no avail.
I like red cars
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #7 on: 17 February 2007, 15:21:01 »
Oh! and the price quoted is £25.
I like red cars
Amarok
  • Peterborough
« Reply #8 on: 17 February 2007, 20:26:42 »
Last time I asked at LMF
http://www.lmfvauxhall.com/content/default.aspx
They had a good stock of these but the chap recommended washing out with White Spirit / Carb cleaner, So I popped to the breakers and got a spare steel pipe and Trap they both washed it out Perfik
Regards
Mike
    • E250 Est / Elroq
« Reply #9 on: 19 February 2007, 08:10:54 »
 :question
Picked one up from stock at Lookers Chester - £7/8
still in the box awaiting fitting  :-[
Matchless
  • Nottingham
    • A white van
« Reply #10 on: 19 February 2007, 10:11:20 »
Regards
Mike
With time the "stainless" steel mesh starts to rust and break up, I dont fancy bits of wire mesh floating around the camcover so I wouldnt risk a s/h one unless it does clean up properly.
