Pages: [1] 2 3  All   Go Down
Author Topic: low beam fld/vision  (Read 11973 times)
madmax
  • costa del essex
low beam fld/vision
« on: 18 February 2007, 09:30:01 »
hi can anyone tell me what low beam fld/vision is on the check display and how do i get rid of it..ps had a side light bulb go recently and replaced it but cant seem to get rid of the display check light...
Re: low beam fld/vision
« Reply #1 on: 18 February 2007, 09:36:24 »
Presumably you have HIDs (if not, your MID is misconfigured).  It means the system is no longer automatically adjusting headlamp height.
Often caused by faulty sensors (one at front, one at rear), or a problem with the levelling servo/feedback system.
madmax
  • costa del essex
« Reply #2 on: 18 February 2007, 09:53:58 »
got xenons and no motor leveling system inside light...where  abouts are these sensors thanxs..
« Reply #3 on: 18 February 2007, 09:56:25 »
yes there is ;)
The sensors are mounted on n/s front wishbone and n/s rear trailing arm.
madmax
  • costa del essex
« Reply #4 on: 18 February 2007, 10:09:59 »
cheers for that info...do you recomend replacing sensors..
« Reply #5 on: 18 February 2007, 10:14:34 »
and they're £51 each :(
I'll keep  acknowledging  mine for a while
You need Tech II really to read the fault. It's the rear sensor that FUBAR'd on mine and I get the message within a minute or so of switching on the ignition whether the head lights are on or not, if that's of any help.
« Last Edit: 18 February 2007, 10:16:32 by Andy_B »
madmax
  • costa del essex
« Reply #6 on: 18 February 2007, 10:19:46 »
£51 each......aaaaaah a trip to the breakers is needed...expensive month this will be mot due in two weeks new wishbones two new tyres front brake discs and pads and new back box no holes in it but air only coming out of one pipe weird..
madmax
  • costa del essex
« Reply #7 on: 18 February 2007, 10:30:26 »
cheeers mate big help shall get in touch with tech II...
« Reply #8 on: 18 February 2007, 10:31:30 »
Exactly what I thought. After I'd had my car Tech II'd I phoned the dealer and ordered one, and just asked as an aside really how much they were! I cancelled the order! :-?
« Reply #9 on: 18 February 2007, 10:35:30 »
Strangely, I think thats quite cheap.....I suppose thats coz I have seen all the gubbins inside one!
Its well worth cleaning all the pivot points and checking all the connectors and wires also....
« Reply #10 on: 18 February 2007, 10:45:32 »
So have I! It's another £50 I could better spend on something else at the minute though. It's just a pity that Vauxhall/whoever made them couldn't have put a spot of lubricant on the ball/sockets of the pivots. When I removed the link arm from the rear the ball was rusty so consequently it damaged the seal of the cup that should've stopped water from getting in in the first place.
Strangly though the height my head lights aim don't appear to have moved. I'd have expected the aim to have moved if the level system doesn't know where the back of the car is.
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« Reply #11 on: 18 February 2007, 18:15:00 »
if the aim hasn't moved it implies that it's not a sensor failure but the HID ECU or adjustment motors.....
if the Sensors fail, the failsafe position is to point the lights down as far as possible.,.. giving a night vision range of about 10 feet!   But without blinding opposing traffic.
inoperative HID lamp Adjustment, is, as I understand it, an MOT fail, even if they're nominally pointing the right way at the test centre (or so i was told)
Max
madmax
  • costa del essex
« Reply #12 on: 18 February 2007, 20:54:08 »
thanx for the advice everyone you all seem to no what your talking about...im a bit lost where are these adjustment motors are they in the headlight...only ive just had to glue mine back  together on the inside a bit of plastic had snapped on the screw adjustment making the light inside move about...
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #13 on: 18 February 2007, 20:58:32 »
The servos are on the back of the headlamp and connect to the reflector via a ball & socket type arrangement
I have an O/S Xenon Headlamp complete with Servo & the Power pack for 1999 if you are interested
Ian
« Reply #14 on: 19 February 2007, 01:08:01 »
Max
..... After I'd had my car Tech II'd ......
It's what the Tech II said. Maybe it was having an off day and was mistaken then!!   ;)  :y
Pages: [1] 2 3  All   Go Up
