low beam fld/vision
Started by madmax, 18 February 2007, 09:30:01
MaxV6
maybe it was.
no need to get cute, i was merely passing on info given to me by the Vx stealer when I enquired as to what the fault was and why my headlights suddenly point at the ground instead of where i'm going.
they were actually fairly forthcoming about what it is, how it works, and what it does and why....    which, admittedly is rather unusual for  a dealer.....
Quotemaybe it was.
Moi!?  ;)
Quotei was merely passing on info given to me by the Vx stealer .....
Like wise , although it wasn't actually at the dealers - the technician came to me.
madmax
QuoteThe servos are on the back of the headlamp and connect to the reflector via a ball & socket type arrangement
I have an O/S Xenon Headlamp complete with Servo & the Power pack for 1999 if you are interested
Ian
its passenger side im after or both if available.....cheers
Where would you stand having tech2 adjust the field to give better view? are there many settings for this?
I ask because the wifes facelift has massively better lights than the mv6  (yes both HID before you ask ;) )
As I'm at the dealer plugged into tech2 anyway next week, thought I may try and blag an improvement, if I know what to ask for that is.
In old terms it's like my headlight adjustment is at '2' compared to '0' on her's
MaxV6
QuoteMoi!?  ;)
hey, someone , somewhere, will have called you cute at least once.......    ;)  no worries, I was just being my usual obstreperous morning self ....  ..... :D
QuoteLike wise , although it wasn't actually at the dealers - the technician came to me.
ooohhh posh....    :D  visiting technicians eh??
all we get round here are DG sales teams and religious nuts....  :-[
;D
QuoteWhere would you stand having tech2 adjust the field to give better view? are there many settings for this?
No Tech2 adjustment. There is a calibration function that should be carried out.
Presumably yours are set to UK setting, not the flat 'universal' setting (which is lower) - double check the levers as per handbook...
Should have thought of that, esp as the car came from 'down south' so could well have been used a bit on the continent.
I belive the expression is 'doh!'
You are a genius!
Got the book out, and there are some biro marks from someone making notes!
Opened the lights and they are set as per the settings in the book, ie continent settings!
Made the change and they look better as far as I can tell in the light, will try properly later.
I Love this place!
QuoteI belive the expression is 'doh!'
You are a genius!
I Love this place!
We love easy (if you have small hands!) fixes :D, so here's hoping thats cured it...
Large hands not a problem here.
Whoever did this liked the brute force approach, the 2 plastic covers above the lights 'wrenched' off and just resting on the top!
Was a van parked in front of me, 1/5 - 2 meters away
Pattern of the lights went from  -  - to more like /  \ and seemed to illuminate about 2 inches higher up the van.
will add a couple of those securing clips to my shopping list!
Quote....
;D
:-[  :-[  :-[  :-[  :y
I assure you that Posh I ain't!!  ;)
Pitchfork
Only got the one it's Off-side (right)
Ian
theolodian
QuoteOnly got the one it's Off-side (right)
Ian
You have a pm.
[move]Trains may have been invented here, but public transport is a foreign concept![/move]
Pitchfork
Ian
You have a pm.
Nothing rec'd, pse resend
Ian
madmax
#29
back again.. cheers everyone for your input on my headlight problem..how hard is it to actually take the headlight apart to get to the inside..ie removing lens....
