And yet again - Air Bag Light
Started by Auto Addict, 12 February 2007, 17:05:43
QuoteWouldn't worry too much about that - the radio comes on when doing some diagnoses, possibly the cheap doesn't fire it up if it detects an error before that point.
Interestingly, the radio must be on during g/box upgrade....
Have you done a gearbox upgrade with a 3rd party headunit?
No.
But apparently, the flash fails part way through if the radio is turned off  ::)  :-X
Auto Addict
24 hours later and it's still off :y
I like red cars
Markjay
No.
To be honest, due to the conditions (wet cold and dark) and the fact that my battery was flattened by the repeated attempts, we did not conduct a very scientific study in the sense that we did not have a control group and we did not try to replicate the findings... but as anecdotic evidence it definitely seems this way.
Alas, no more Omegas....
Markjay
AA, having given this some further consideration... I don't see how pursuing the warranty avenue can help. If the suspected faulty sensor is sent back to Vx, then they will either test it using some sort of test rig, or just hook it up to a ECU and see if it flags-up an error code – but because the fault is intermittent, it will seem Ok and they will send it back saying no fault found. It is unlikely that they will actually fit it to a car and drive around with it for a couple of weeks... So it would seem that you will need to sort this one out on your own?
Incidentally, now that you have reset the airbag light with the Cheapo Tech-II, doesn't it look like a very good investment compared to Vx charge of £45 for each reset?  ;D
Auto Addict
QuoteAA, having given this some further consideration... I don't see how pursuing the warranty avenue can help. If the suspected faulty sensor is sent back to Vx, then they will either test it using some sort of test rig, or just hook it up to a ECU and see if it flags-up an error code – but because the fault is intermittent, it will seem Ok and they will send it back saying no fault found. It is unlikely that they will actually fit it to a car and drive around with it for a couple of weeks... So it would seem that you will need to sort this one out on your own?
It's already paid for itself :y
I like red cars
Taxi_Driver
Quote24 hours later and it's still off :y
Shame you carnt borrow another one and see if the intermittant fault stays with the car or moves with the sensor.......wonders if TB can swap it with Tunnies without him noticing  ::) ;D
Auto Addict
I could send you the old one and you could try it in yours........ ;)
I like red cars
Taxi_Driver
That wouldnt be a problem AA...tho i carnt remember.....would there be enough room at the bottom of the door for 2 sensors....ie your old one just resting in the bottom of door without getting in the way of window etc......coz i know my sensors are rivited in....and i get nervous about drilling rivits out holding an airbag sensor in!
Auto Addict
All you have to do is disconnect the battery first ;)
I like red cars
Auto Addict
Still no sign of the airbag light, 5 days and counting :y
I like red cars
Taxi_Driver
The point I was making earlier, it doesn't seem to matter whether the audio is switched to tuner or tape, as soon as I plug in, it goes to CD.
It doesnt on mine  :-?
But then i dont have tuner/tape/cd.....just tuner/cd if thats makes a difference
Auto Addict
Mines an upmarket CD ;D
I like red cars
Taxi_Driver
Not after tonight  ;D
PS can you leave it unlocked to save breaking the window  :D
Auto Addict
I like red cars
