And yet again - Air Bag Light
Started by Auto Addict, 12 February 2007, 17:05:43
Auto Addict
QuoteDoes anyone know if JamesV6CDX airbag ECU off the car he is breaking will fit my facelift?
First job now, I'm going to check the connections behind the drivers kick panel.
Will post again shortly.
Its pre mini facelift, so want have one...
That's the end of that idea then.....
I like red cars
Auto Addict
I like red cars
Auto Addict
I like red cars
jud1255
hiya mates just got my tech2 cheapo
befor i attempt to use it can somebody just run through the sequence with me .
heres what ive done on pc but without connecting to car
opened
Opel diagnostics tech 2 supplied with , the clicked the following's
diagnostic
1998
omega b
body
airbag sab6
what is the next sequence or sequences to put the airbag light out is it straight forward .
I know,might be easy but better safe than sorry i say.
thanks mates
Yes....click on read codes....then click on erase codes.....
Auto Addict
Click on the button, Error Code (it may say read error codes).
It should list the error code(s) if any.
Then the button Clear Codes ( or it may say - reset codes) should be active - click on that and it should clear the code(s).
I like red cars
jud1255
#66
great guns thanks for speedy reply
cheers
Auto Addict
You will need the ignition switched on (not engine running) when it's plugged into the car to be able to read the codes.
I like red cars
jud1255
ok i got that.
what about radio cos i seen previousley where some has radio and some cd etc
or doesnt that matter
Auto Addict
Quoteok i got that.
It doesn't matter.
I like red cars
Markjay
#70
I think the point about the radio is that if it switches itself on at any stage, just leave it as is until you're done with the Tech2 and don't be tempted to switch it off...
Alas, no more Omegas....
jud1255
ok thanks to you all ,you are the best.
thanks again
Auto Addict
This does seem to be quite a common problem with the airbag sensor, on the other site people have got problems, and I noticed Cateras seem to have the same problem, don't know about Opels, can't read German....
Strange.......not strange I can't read German, before someone makes a wisecrack ;)
I like red cars
jud1255
yeh mine came on while trying to start the engine when the battery was flat , ill take caution next time , then again if this tech2 works, when i get round to using it. I wont have to , im just trying to locate a laptop now rather than bring the car in the house to the pc i dont think she would like that the other half that is.
Ha ha
either that or a very long serial cable
