Locking Wheel Nut !!!! HELP !!!!
Started by Joe, 30 April 2007, 12:37:37
Joe
Hi all,
Just picked up a omega Elite for spares and it came with a set of vauxhall 17" alloys on it BUT the idot who sold it to me had lost the locking nut!!
Now before with this i usally just beat on a socket and wind it off - But That wont work on this !!
Here is a pic of one
Anyone got the key for it !!!!
Hmmmmm  Love the smell of burnt rubber in the morning !
Craig_R
#1
I think Halfaurds do a Kit for taking off Locking Nuts If Your Stuck and the bashing a smaller socket on will not work
Mod's
[To be Fitted]Reverse Sensors
Joe
Have tried both - if you look at the pic the outer rim moves on it's own - so when i stick a socket on it just moves the out rim.
nixoro
Worth a try but would a small cole chisel not budge them. :-/
Admin
#4
Alas through personal experience, I can tell you that a chisel and a LOT of beating is the only way to get these off if you don't have the key!
The Administrator.
would one of those weird sockets made up with a load of pins to fit a shape work here?
Gator grip I think
http://www.endeavorproducts.com/ggrip/ggrip.html
nixoro
QuoteAlas through personal experience, I can tell you that a chisel and a LOT of beating is the only way to get these off if you don't have the key!
Same here been in a situation where my Mums old Cavalier had some locking nuts fitted, some plank at the tyre place had used a gun with the adapter and knacked the adapter.
In the end I spent best part of a day drilling out a lockable nut then finishing with a cole chisel.
ClarCE
I had this on an astra - I drilled three holes (about 10 drill bits and TWO drills later) and then smacked a chisel in to join the holes - then turned that with a t-bar...
So Far - :: Re-Finished Elite Wheels :: Black Leather Interior :: 3.0 Cams :: Chipped (REMOVED, EBAY SHI*E) :: Facelift Skirts ::
To Do   - :: Facelift Rear Bumper, Door Mouldings :: Irsmsher Front Air Da
ricardo1500
You may find that you can remove the outer collar that spins by splitting it with a small chisel, then bang a 13/16 socket on whats left and bobs your moms brother!  Thats how mine came off. Oh and grind the chamfer off the socket so it bites better
Dave-C
Looks like a GM locker to me...  They're well secure it would seem....  Try having a word with the mechanics at your local VX dealer, see if they'll help for a pint or two...  don't go thru service reception!!!!!!!!! ;)
