Author Topic: Remote key operation - hmmm  (Read 2927 times)
mv6copcar
  • Essex, Halstead
« on: 02 May 2007, 08:28:13 »
i have a 2000 w facelift saloon, for the last 8months the remote has only been able to unlock the doors, i can only lock the doors with the key in the door and open the boot buy the button inside the car-very annoying now!!
i cant see that its needs reprogramming as the remote unlocks the doors evey time-??
thanks people
carl
Admin
Re: Remote key operation - hmmm
« Reply #1 on: 02 May 2007, 12:24:29 »
That is a peculiar one.
Try "re-synching" the remote first.
Sit in car, turn ignition on, press button on remote. Doors should lock and immediately unlock.
If this does not work, then I suspect a sticking door lock solenoid.
The Administrator.
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #2 on: 02 May 2007, 19:13:27 »
it could well be that the switch for the "lock" button is faulty ... does your remote have a little red light that comes on when you press the unlock button, if so does it also come on when you press the lock button?
As it locks fine with the key I'd suspect the door locking solenoids are probably OK ... the switches in the remotes aren't very clever anyway ...
STMO123
« Reply #3 on: 02 May 2007, 19:40:35 »
I thought this straight away but stopped short of posting because of the boot issue :-/
« Reply #4 on: 02 May 2007, 19:48:14 »
i suspect a kackered remote button...
sounds2k
« Reply #5 on: 02 May 2007, 19:56:19 »
... do you have a spare key and if so do all the buttons on that work? That would prove if the problem lies with the key or not ...
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #6 on: 02 May 2007, 21:17:13 »
On a reccomendation from another subscriber to this forum, I resoldered the battery connections to the circuit board inside the key fob & the problem was solved
I am happy to resolder yours if you like - it may be the same problem
IW
mv6copcar
  • Essex, Halstead
« Reply #7 on: 03 May 2007, 14:54:27 »
thanks for the responces.
the red led flashes in the key when pushed but the car does nothing.
only unlocks(after locking the car with the key!)
go to vauxhall to get the key reprogrammed??
Regards
Carl
« Reply #8 on: 03 May 2007, 14:57:10 »
Regards
Carl
The key is programmed fine - your issue is with the remote I suspect, probably duff buttons.  Possible the lock mech on the car is knackered, but I think you would see it attempt to lock...
sounds2k
« Reply #9 on: 03 May 2007, 23:50:22 »
does the red light in the key flash each time you press a button - for lock, unlock and boot release? or just for unlock?
if it flashes for all 3 operations then I reckon that rules out the switches in the key ...
Pitchfork
« Reply #10 on: 04 May 2007, 07:29:51 »
The lights flashed on mine too but failed to operate the locks until I resoldered the battery joints
Suggest you try this as it costs nothing & takes very little time
That way if it doesn't remedy the situation you can stsrt worrying about more expensive options!
IW
« Reply #11 on: 04 May 2007, 09:43:48 »
Seen a few where the LED flashes, but still needed touching up with iron to get to work...
    • E250 Est / Elroq
« Reply #12 on: 04 May 2007, 10:05:05 »
Just resoldered my own (for the 2000 cdx), I have a theory....
My key, sometimes worked, often didnt, when it did, it would often trigger the alarm!  Car needed to then be started to turn it off.
I reckon the rolling code system get confused with a freqently connecting / disconnecting battery, thus confusing things.
Every successful key operation sort of resync's the key.
So I think if the key doesn't have a constant power supply, regardless the key flashing, ie doing something, it may not be fully sync'd to the car.
probably completely wrong, but does seem to fit my experiences.
« Last Edit: 04 May 2007, 10:05:40 by jimbob »
mv6copcar
  • Essex, Halstead
« Reply #13 on: 04 May 2007, 10:41:33 »
tried the resoldering last night,put a new batt in but still the same, the lights flash fine but only the unlock button works!! may just give up lol
thanks
