Author Topic: no side lights  (Read 4155 times)
paulmollie
no side lights
« on: 15 May 2007, 18:41:47 »
front side lights not working fuse ok had multimeter on terminal showing 0.01v anyone got any ideas---------------------------------------cheers
Re: no side lights
« Reply #1 on: 15 May 2007, 18:50:53 »
Are F23 and F30 ok....are the tail lights working......do the parking lights work?
paulmollie
Re: no side lights
« Reply #2 on: 15 May 2007, 19:04:36 »
fuses ok rear parking lights fine zilch at the front
Re: no side lights
« Reply #3 on: 15 May 2007, 20:15:11 »
...and do the parking lights work?
paulmollie
Re: no side lights
« Reply #4 on: 15 May 2007, 20:20:49 »
only the rears
paulmollie
Re: no side lights
« Reply #5 on: 15 May 2007, 20:22:29 »
sorry this should be in the electrical section can you tell i'm new here?
Danny
  • Wigan, Greater Manchester
Re: no side lights
« Reply #6 on: 15 May 2007, 21:05:20 »
have you checked the bulbs?
sorry, i know it sounds like a silly suggestion..
Re: no side lights
« Reply #7 on: 15 May 2007, 21:21:19 »
So....
They dont work off the light switch....
and they dont work with the indicator switch in the left or right position and the keys removed from the igniton....
The tail lights work (which actualy sudgests the light switch is ok), and the bulbs are both ok....
Sorry for what might seem daft questions, but I am basing them on possibly failure scenarios having studied the wiring diagrams...
« Last Edit: 15 May 2007, 21:22:19 by Mark »
Re: no side lights
« Reply #8 on: 15 May 2007, 21:47:14 »
if it had dim-dip unit fitted, and it failed, could that be a possibility?
Re: no side lights
« Reply #9 on: 15 May 2007, 21:50:24 »
Never was one fitted to the Omega....even with day running light module in it wouldn't cause this....these bulbs arnt even monitored by the check control either and the rear lights are wired in parralel with them....
paulmollie
Re: no side lights
« Reply #10 on: 16 May 2007, 20:10:23 »
the bulbs look fine there is no power to them i checked with a meter yet the rears are fine   ........strange
kcl
  • Finland
    • Volvo V60 D4 -14
Re: no side lights
« Reply #11 on: 18 May 2007, 12:08:40 »
No help coming from here, just more questions: Side lights? Meaning indicators on the front wings? Or "american"style side lights (which I don't have)? Or am I missing something...?
Danny
Re: no side lights
« Reply #12 on: 18 May 2007, 12:57:45 »
the side lights are the small bulbs, same colour as headlights, but not quite as bright, use for low light when its not quite dark enough for headlights!
Re: no side lights
« Reply #13 on: 18 May 2007, 14:10:47 »
I believe in Finland you have dim-dip units, so you may not know about sidelights. They are a small bulb (5w) that sits in headlights...
