Pages: 1 ... 12 13 14 15 16 17 18 [19] 20 21 22   Go Down
Author Topic: Oh Bugger - The END?  (Read 87499 times)
Allenm
  • Milton Keynes
Re: Oh Bugger - The END?
« Reply #270 on: 05 October 2006, 20:46:32 »
Yup, I'll chuck the kit in car, not sure when I can get up to you (unless you can get down to Bletchley?)
I can get to Bletchley no problem,  just need to know so I make sure I drop the wife at work and keep her car.  If you are in Bletchley tomorrow, I could pop over.  If you are near a Pub all the better [smiley=beer.gif]
« Reply #271 on: 05 October 2006, 20:57:26 »
I'm in Bletchley tomorrow, camlock and 30mm spanner in boot. I'm there from 9am until 4:30 ish, but alas cannot get out. You're welcome to come and pick up at any time, but I may be in a hurry :(
Allenm
  • Milton Keynes
« Reply #272 on: 05 October 2006, 21:04:45 »
OK, PM the address and what is likely to be the best time.  Dont need to 30mm spanner, just the kit.
Cheers
MartinP
  • Dudley
    • BMW 320D
« Reply #273 on: 05 October 2006, 23:33:05 »
I have a 3m x 3m material type gazebo. Being material, not entirely sure how waterproof it is if it gets really wet...
Also got a gazebo that I can chuck into the back of the motor if required.
« Reply #274 on: 06 October 2006, 09:33:10 »
Camlock and gazebo in boot, awaiting your collection :)
Allenm
  • Milton Keynes
« Reply #275 on: 06 October 2006, 09:40:48 »
Aiming for around 11:00 if that is ok.  Will ring first.
« Reply #276 on: 06 October 2006, 09:49:54 »
Sounds good.  Got a few pointless audio conferences today, so if landline engaged, use mobile number ;)
Matchless
  • Nottingham
    • A white van
« Reply #277 on: 06 October 2006, 10:07:54 »
Merv,
If you can strip down to where you were for cambelt replacement that will save time, also drain radiator and remove water pump again to empty the block, that way we shouldnt have to lie in antifreeze on the day.
Can you provide a power feed for work lights?
Allenm
  • Milton Keynes
« Reply #278 on: 06 October 2006, 10:57:16 »
Merv,
Ok will do.  Power is no problem, I will make sure that there are at least 2 extension leads to use.
Allenm
  • Milton Keynes
« Reply #279 on: 06 October 2006, 16:28:35 »
Merv,
Will I need to get a new seal for the pump, or is it likely to be OK (new on a couple of weeks ago).  I'm also guessing I just remove the belt, not the tensioners etc, if so these will need new bolts (according to haynes).
« Reply #280 on: 06 October 2006, 17:36:14 »
Belt and tensioners off....back plate has to be removed to do the heads....seal should be fine.
Issunaz.....Gazebo would be good just in case.
« Reply #281 on: 06 October 2006, 18:16:52 »
Allenm has my 3m x 3m gazebo (its only cloth, not sure how waterproof if there is big downpour), also has locking kit for cambelt.
Allenm, anything else you need, or if you need a hand with anything, just let me know...
Allenm
  • Milton Keynes
« Reply #282 on: 07 October 2006, 09:28:05 »
Ok, No problem,  are the bolts on your shopping list, or should I nip out to VX this week and get some replacements?
Ta
Merv
« Reply #283 on: 07 October 2006, 09:38:05 »
Bolts are re-useable as they are not stretch ones....plus I have a few spares ayway.
UncleFugger
  • Limassol, Cyprus.
« Reply #284 on: 07 October 2006, 10:23:47 »
Hi Guys, been watching this thread for the last couple of days since I joined. It's addictive vieiwing, a bit like a soap  :) I think this site is great, being able to follow something and learn alot. Hi hope this sorts out for you Merv! I know what it's like going to work and leaving you meega on the drive every day :(
Good luck guys, I'm following this closely as in the next couple of weeks I'm going to be changing my cam belt and this is invaluable information - Thanks!!!
Pages: 1 ... 12 13 14 15 16 17 18 [19] 20 21 22   Go Up
Page created in 0.024 seconds with 20 queries.
