Author Topic: Rear view mirror......  (Read 1635 times)
pogo
« on: 06 December 2007, 23:33:18 »
Been a bit silly.... and now going to look silly....
.. so I was sat waiting in the car (as you do) and started to play with the seat memory buttons... thought this is good, after laughing out loud at setting 3...vertical! I managed to wipe all 3 set in the memory (not sure how!) I then re-adjusted the seat to a driving possition, went to move off, went to check the rear veiw mirror and it was pointing up to the head linning, I can feel alot of resistance so im guessing its another electrical toy.... my problem is where the hell is the adjuster or is in not electric and was I beeing to soft with it???
« Last Edit: 07 December 2007, 10:06:52 by Mark »
    • E250 Est / Elroq
Re: Rear veiw mirrow......
« Reply #1 on: 07 December 2007, 07:53:52 »
Havent got one myself, but think the procedure is set seat, AND Mirror, then set the memory.
All should return on selecting that memory.
Hope this helps.
« Reply #2 on: 07 December 2007, 08:21:04 »
The interior mirror is electrically opperated but you move it by hand to where you want it first & then set the memory on the seat. My driver's seat will lose its memory position if you move it to an extreme setting, ie it doesn't quite get back to where it was to start with. If you just move the seat & mirror from each of the stored settings it's OK
Paulus
  • Wheaton Aston
  • Are you lookin' at me??? Punk???
Re: Rear view mirror......
« Reply #3 on: 07 December 2007, 09:08:57 »
Mine goes exactly to the set position every time. It is a bit still to move manually, but then again, you don't want it flopping about do you?
« Last Edit: 07 December 2007, 10:07:11 by Mark »
Growing old disgracefully...
