e.c.u water temp control switch
Started by X30XE . MV6, 09 February 2008, 22:51:48
X30XE . MV6
hello there can any one tell me were this switch is located on the car because it's a real bugger to start from cold and the rac man said it was this switch that was at fault
thank's guys
Quotehello there can any one tell me were this switch is located on the car because it's a real bugger to start from cold and the rac man said it was this switch that was at fault
thank's guys
coolant bridge - its the one with the proper connector, not spade one
X30XE . MV6
HELLO MATE DO YOU WERE IT IS SITUATED ON THE CAR ONLY I HAVE ONLY HAD IT FOR A WEEK
CHEERS
QuoteHELLO MATE DO YOU WERE IT IS SITUATED ON THE CAR ONLY I HAVE ONLY HAD IT FOR A WEEK
CHEERS
coolant bridge is between the V at the back. Basicaly, plenum off, the next part of the intake off, then its easily accessible.  You may be able to get to it with just plenum and scuttle off.
CHEERS
Coolant Bridge.
Plenum off, dependin on small your hands are you may reach it with the fuel injection stuff on... if not, off with that too.
Small brass bolt, in the centre of the coolant bridge.
Btw capitals are considered shouting!
CHEERS
Coolant Bridge.
Thats the dash gauge one tunnie, engine ecu one is the one with proper connector screwed in back of coolant bridge.
X30XE . MV6
THANK'S MATE very gratfull i will change it int he morning
thank's again :y
CHEERS
Coolant Bridge.
Ahh ok yeh, i remember a large ish standard looking connector on the back of bridge, similar to the ICV loom connector?
CHEERS
Coolant Bridge.
Thats the one tunnie :)
X30XE . MV6
sorry people i'm not very good with the computer side of life i keep catching the caps lock button
Quotesorry people i'm not very good with the computer side of life i keep catching the caps lock button
no worries, we were all new to all this once :)
Have you done a paperclip test??
There could be other reasons for it not starting. I would have thought the engine temp sensor would have nothing to do with the engine starting/cranking?
It may stop it firing, as ecu will get mixture wrong
Stand corrected  :y
X30XE . MV6
if i hold the throttle down to the floor and then bring it back half way it will start but it is smelling with fuel and sounds like it's only running on 4 cylinders but me being me useless with cars it coul be the way i'm trying to start it its the first vauxhall i have ever had i'm only used to my claasic capri really
cheers :y
