Author Topic: omega cutting out at speed  (Read 2516 times)
rab
« on: 07 February 2008, 19:57:15 »
hello i`m new, but have been looking on this site for a little while. i have a 2.0 omega manual,aint been running right for a while,after seeing the same problem on this site i cleaned the throttle body and the air flow meter and the breather pipes about a month back and it has been running perfectly up untill the start of this week. my new problem is i drive about 7-10 mile then i lose power for a few seconds, then it will cut out, will start up again straight away but with the engine management light on, while the light is on it wont cut out, once parked up after an hour  will start up with out the light on and repeats the same process, done a diagnostic check but nothing is showing up, any ideas any one.
Dazzler
  • Haverhill, Suffolk
Re: omega cutting out at speed
« Reply #1 on: 07 February 2008, 20:04:19 »
What year is the Omega??
So you have done a paper clip test, and the only code you get is 12?
rab
« Reply #2 on: 07 February 2008, 20:11:41 »
its a 1998 on an r reg,aint done the paper clip test, but had a mate plug in a diagnostic machine in but said he could not find any thing wrong
rickyboy
  • Glasgow
« Reply #3 on: 07 February 2008, 20:27:19 »
You need to do a paperclip test.  There will definitely be a code stored if the engine management light has been on, ignore your mate with the diagnostics machine.  Heres instructions how to do the paperclip test.  Search for your model at the bottom of the page, it will tell you which ecu you have.  You will find your diagnostics port under your steering wheel where the fuses are kept.
http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm
« Last Edit: 07 February 2008, 20:28:08 by rickyboy »
rab
« Reply #4 on: 07 February 2008, 20:35:55 »
ok thanks mate, will do the paper clip test on the weekend
Grumpy
  • Manchester
« Reply #5 on: 08 February 2008, 10:12:45 »
Don't forget to do your paperclip test with ignition on
but engine NOT running. Or you won't get any codes.
Being a 2.0L '98, I would expect 4 digit codes, not 2 digit.
10 flashes equals 0 (zero).
Your symptoms are the same as you would get for a Crank
Sensor that is starting to break down, but the codes will tell
you, so no jumping to conclusions.  ;)
EGGY2
  • N.IRELAND
« Reply #6 on: 08 February 2008, 21:48:20 »
Hi everyone, driving home tonight and my engine management light came on for a couple of mins, just after doing the paper clip test not really sure what it means.. starts with one flash pause then two flashes repeats this three times, then nine flashes pause three flashes, seven flashes pause three flashes, three flashes pause one flash, then it goes back round again can anyone help please??
Dazzler
« Reply #7 on: 08 February 2008, 21:55:43 »
First is code 12- normal, start test code, and is repeated 3 times.
All the codes should repeat themselves 3 times, is this what happened?
So you have 12, 93 and 73 correct?
Dazzler
« Reply #8 on: 08 February 2008, 21:56:16 »
oh, and 31.....
EGGY2
  • N.IRELAND
« Reply #9 on: 08 February 2008, 21:59:16 »
Thats right 12,93,73,an 31 is that bad??
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #10 on: 09 February 2008, 00:15:56 »
12 = start of test
93 = Hall Effect Switch (low voltage)
73 = air flow sensor (low voltage)
31 = Crankshaft sensor (no Signal)
I am guessing that the engine was switched off when you did this, try it with the engine running and see what codes come back
M Kerr
  • Birmingham
    • 2.5 GLS Omega, X Type
« Reply #11 on: 10 February 2008, 21:18:02 »
Sorry to interrupt!  What is a "paper clip test"?
rab
« Reply #12 on: 10 February 2008, 21:30:41 »
you will be able to find it on previous posts,they can explain it much better than i ever could
rab
« Reply #13 on: 10 February 2008, 21:45:22 »
problem sorted now it was the cam shaft sensor, thanks for you help guys. :y
