MAF Voltage High error
Started by Jimbob, 18 February 2008, 10:04:08
Been checking for codes (and resetting airbag) a lot lately
Often have a High Voltage error for MAF
occasionally for IAC as well.
Anything I should be looking to do?  clean / replace?
Or is it likely due to the cold or something daft?
does the performance of car changes with temperature ?
Always goes a bit better when cold, but they all do.
Apart from that no.
Fuel consumption does seem a little lower than normal though :(
low fuel consumption generally shows estimated air flow..
Mine did similiar..
Not very critical..
ps: forgot to add after I changed the MAF performance is nearly
same for different temperatures..(at least I dont see any difference now)
