Paper Clip Error Codes
Started by MutantCav, 23 February 2008, 14:57:53
MutantCav
Just done a paperclip test on the 2.5 v6 and it came back with the following codes... is there a full list anywhere on here?
21 Throttle Position Sensor High Voltage
73 MAF Low Voltage
57 Idle Speed Control Valve (ISCV) Interruption
Are the explanations correct (searched them online) and any potential solutions?
Could these be caused by an air leak??
Markjay
lonely post alert... just to bring this one back to the top.  ;)
Can anyone help Chris?
Alas, no more Omegas....
MutantCav
Cheers Mark :) Not your normal codes I would have said, so surely some of the most wisely people on here will know??
I've had some MAF and IACV faults......blanking the EGR solved them!
Not the exact faults you have, think i had the 57, and a 74, Maf high voltage
Didnt have them both together though, seemed to be one or the other.
QuoteJust done a paperclip test on the 2.5 v6 and it came back with the following codes... is there a full list anywhere on here?
73 MAF Low Voltage
Concentrate on the TPS to start with, the others might well be rogue
Check the connector and wires for damage.
MutantCav
Where is the throttle position sensor mate? :)
QuoteWhere is the throttle position sensor mate? :)
right hand side of throttle body
MutantCav
And you knew this was coming...what does it look like? lol
QuoteAnd you knew this was coming...what does it look like? lol
Look at throttle body. Left side you have all the throttle/cruise cables etc. Right side, you have a single electrical connector.  This is the sensor :)
MutantCav
Oh...might be the bit I swapped over then when I swapped the EGR/plenum from another car to try and rectify the problems, had to keep the sensor because it was different on the mini facelift engine I have to the 95 elite engine the plenum/EGR came off...any way to test if the sensor is faulty other than swap it for a known good one?
