Pages: [1] 2 3  All   Go Down
Author Topic: misfire code 19  (Read 5303 times)
JonR
  • Gloucestershire
misfire code 19
« on: 12 April 2008, 20:49:16 »
evening all, have a miss fire at any thing above 4000-4500 Rpm. In any mode Auto or sport. fault Code came back as 144 and 19 no Rpm Signal and no immobiliser signal. what sensor will cause code. 19 no Rpm signal?
 thanks Jon
    • 530D M Sport, 330i Coupe
Re: misfire code 19
« Reply #1 on: 12 April 2008, 20:51:21 »
Assuming it's a V6 then your crank sensor needs replacing..... Urgently!
Re: misfire code 19
« Reply #2 on: 12 April 2008, 20:51:49 »
code 19 is crank sensor.
change this ASAP, it will let you down at worst time!
dead crank sensor  = dead car!
Dazzler
  • Haverhill, Suffolk
Re: misfire code 19
« Reply #3 on: 12 April 2008, 20:53:04 »
Can't say fairer than that ;D
JonR
  • Gloucestershire
Re: misfire code 19
« Reply #4 on: 12 April 2008, 20:54:51 »
how much new and easy ish to change? , lm a dab hand with Spanners too
Re: misfire code 19
« Reply #5 on: 12 April 2008, 20:56:38 »
forget the price, £45 ish i think?  :-/
Easy as pie to change, 1 torx bolt, sensor is next to the oil filter (if yours is a V6)
Re: misfire code 19
« Reply #6 on: 12 April 2008, 20:57:35 »
Around £40 or £70, depending on type, About 30mins if you follow guide on here ;)
Re: misfire code 19
« Reply #7 on: 12 April 2008, 20:57:47 »
Easy to change, follow this guide and make sure the cable is routed as suggested.
http://www.omegaowners.com/forum/YaBB.pl?num=1174321688
I paid about £50 but you need to identify which one you require.
JonR
  • Gloucestershire
Re: misfire code 19
« Reply #8 on: 12 April 2008, 21:00:18 »
lm impressed, thanks everyone :D
Re: misfire code 19
« Reply #9 on: 12 April 2008, 21:01:30 »
No Problemo  :y
JonR
  • Gloucestershire
Re: misfire code 19
« Reply #10 on: 12 April 2008, 21:04:06 »
shall I ignore 144 seeing as car runs Fine other than the misfire?
Re: misfire code 19
« Reply #11 on: 12 April 2008, 21:06:20 »
Yup
JonR
  • Gloucestershire
Re: misfire code 19
« Reply #12 on: 12 April 2008, 23:37:26 »
is it worth getting a 2nd hand one From a Breakers?
Re: misfire code 19
« Reply #13 on: 12 April 2008, 23:42:49 »
No, you won't be able to extract the cable from the loom (fitted at factory), It's usually the routing of the cable (near the manifolds) that causes the failure.
A new sensor and the routing suggested in the guide is the best solution.
Re: misfire code 19
« Reply #14 on: 12 April 2008, 23:43:24 »
not unless your very skint,they seem to packup after they get to a certain age and can stop working very suddenly ,leaving you stranded. i remember reading that it hapened to the boy in the middle of france :o
Pages: [1] 2 3  All   Go Up
