Author Topic: Now I'm getting code 19!  (Read 2055 times)
trebor
  • Swindon
« on: 18 April 2008, 14:24:25 »
So, 57,59 and now 19.   Though no 31 - is that cause I get 19?
What is the part no. I'll need?  And looking at other threads - genuine vaux only?
Mr_P
  • Nottingham
Re: Now I'm getting code 19!
« Reply #1 on: 18 April 2008, 16:52:20 »
Have I got the right codes for your car?
19 Incorrect Revs per Minute (RPM) signal (crankshaft sensor) Incorrect signal, check sensor
57 Idle air control Voltage low
59 ... ?
« Last Edit: 18 April 2008, 16:56:43 by Mr_P »
trebor
  • Swindon
« Reply #2 on: 18 April 2008, 17:07:42 »
Yes, and
59 Inlet Manifold valve 1 (at the rear of the engine I think) voltage low
Mr_P
  • Nottingham
« Reply #3 on: 18 April 2008, 17:43:08 »
If you look on ebay for "omega crank shaft", often the ads list the vaux part numbers along side the engines they fit.
eg. one of the few listed at the moment.
 Omega B 1994-2003; X25XE, Y26XE, X30XE, Y32SE engines
*We can also supply the later crank sensor with the oval plug 3 pin for same vehicles at £44.00 - Part number 90492061*
Vauxhall part number 90492006
    • 530D M Sport, 330i Coupe
« Reply #4 on: 18 April 2008, 17:46:26 »
Replace the Crank Sensor first, then worry about the other codes. Crank sensor failure / failing can kick up other codes because the ecu is getting the wrong info.
trebor
  • Swindon
« Reply #5 on: 18 April 2008, 18:20:07 »
ok, sounds like a good plan :)
will mine be an earlier or later sensor?
« Reply #6 on: 18 April 2008, 18:40:09 »
Need to unplug it where it plugs into the loom and have a look at the plug and see what style it is.
Likely to be later style - 90492061 - but you really do need to check!
trebor
  • Swindon
« Reply #7 on: 18 April 2008, 19:10:21 »
Whereabouts is the connector located?
« Reply #8 on: 18 April 2008, 19:39:23 »
It's somewhere around the cable tray on the nearside, I think the location varies but you are simply looking for the three pin plug.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #9 on: 18 April 2008, 19:47:37 »
My Mrs's car is a 1998 R reg. I bought a new Crank Sensor yesterday from Vx, which they call Oval (but is rectangle with radiused corners) part number 90492061 for  £49.35 using TC...
I personally would not buy another CS off ebay as mine broke down within 6-8 weeks and the price wasn't much difference either >:(
the "Oval" one looks like this mate.. the connector on the right is the wiring loom on the car, the connector on the left is the Crank Sensor.
Also have a look at the How too
http://www.omegaowners.com/forum/YaBB.pl?num=1174321688
« Last Edit: 18 April 2008, 19:53:51 by Loo-knee »
