Pages: [1] 2 3  All   Go Down
Author Topic: Knocking over speed bump  (Read 6297 times)
prestigesec
  • Wirral
« on: 20 April 2008, 23:25:46 »
Eventually got my omega estate 3.0L elite with all the toys for a very good price, needs a couple of bits doing though. One is when i drive over a speed bump or hit a pot hole there is a knock from the front as if something is loose it also does it when you hit the brake sharply. Car will be going up on the ramp tomorrow so just like to know whats the common thing that this could be so we are not wastin loads of time looking everywhere? Many thanks Steve.
Re: Knocking over speed bump
« Reply #1 on: 20 April 2008, 23:27:26 »
Drop links, front suspension.  £9 each off ebay - ½hr each side to fit.
« Reply #2 on: 20 April 2008, 23:32:24 »
or ...... (holds coat ready) it might be cheaper in the long run to buy the 'proper' thing from Vx. 'Buy cheap fit twice' ......
prestigesec
  • Wirral
« Reply #3 on: 20 April 2008, 23:34:56 »
Hate doing things twice, so how much from vauxhalls?
« Reply #4 on: 20 April 2008, 23:37:23 »
 :-[ Can't remember! I think SWMBO's Astra's drop link was about £20
Are you  a member of the Autobahnstormers Club? There's a member who fitted 2 drop links to his Monza, 1 of them was a 'proper' one from GM & the other was A N Other cos the dealer only had one. 'They look the same' he thought 'It'll be OK this once' 2 years down the line the OE GM part was still perfect, A N Other part was fubar'd.
« Last Edit: 20 April 2008, 23:42:38 by Andy_B »
prestigesec
  • Wirral
« Reply #5 on: 20 April 2008, 23:45:08 »
That'll do not bad price really, paid £75 for the ones on the scoob
FRE07962128
« Reply #6 on: 21 April 2008, 05:45:35 »
What does a 'drop link' do please, and where located? :o :o
Lizzie Zoom :D
« Reply #7 on: 21 April 2008, 08:32:23 »
Other members have recommended the cheapos off ebay & have found them to be ok.
« Reply #8 on: 21 April 2008, 08:35:19 »
Beware the cheap, cheap ones......thw FAI branded ones seem ok.
Vx ones are about 30 quid each and not much better than the FAI ones.
« Last Edit: 21 April 2008, 08:35:53 by Mark »
Mike Collins
  • North of Bristol
« Reply #9 on: 21 April 2008, 08:37:03 »
Worn wishbone bushes will make a similar noise.
Droplinks you could remove and try without to isolate the source of the noise.
« Reply #10 on: 21 April 2008, 08:39:42 »
Lizzie Zoom :D
Located at each end of the anti-roll bar.
FRE07962128
« Reply #11 on: 21 April 2008, 09:08:35 »
Lizzie Zoom :D
Something else I have learnt!   Cheers.  Lizzie Zoom :y
« Reply #12 on: 21 April 2008, 10:21:48 »
Check for play in front suspension, in particular wishbones. If none found, it will be droplinks.
Padster
  • Gravesend
« Reply #13 on: 21 April 2008, 11:17:48 »
I've got the same noise, so do i jack the wheel off the floor and give it a tug on opposite sides like you do to test wheel bearings on m/cycles? I've looked at the wishbone rubbers and they look like they're peeling (similar to that of an onion) so could that be the problem?
** Kenwood Head Unit + 12" Kenwood Sub / Vibe Amp ** Hillper's Boot Mod ** HID Coversion **
« Reply #14 on: 21 April 2008, 20:07:25 »
Difficult to check drop links - if really knackered you will feel play on joint if you pull it backwards and forwards.
Difficult to concentrate on reply - do u look like your Avatar?
« Last Edit: 21 April 2008, 20:09:45 by dbug »
Pages: [1] 2 3  All   Go Up
