Author Topic: Traction Control Button  (Read 3453 times)
« on: 21 April 2008, 09:48:30 »
Does anyone know when the TC button moved from the area to left of radio up to above radio on prefacelifts?
I think I know the answer, but just what to confirm if its other peoples experience.
Dazzler
  • Haverhill, Suffolk
Re: Traction Control Button
« Reply #1 on: 21 April 2008, 09:55:02 »
When they changed to mini-facelift, so  98ish :-/
« Last Edit: 21 April 2008, 09:55:26 by Dazzler »
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« Reply #2 on: 21 April 2008, 09:59:12 »
i have minifacelift, 98. back of traction control button switch is present behind satnav screen, same size as taller button, but button not present, not even rerouted to where blank switch was above radio. traction control appears to be automatic with no option to switch off. this may have been a different story if i didnt have satnav fitted. dont know if that helps or confuses the issue for you!!?
PM with your requests.
« Reply #3 on: 21 April 2008, 09:59:36 »
Have r reg estate - tc switch to left of radio - reg early 98
s- reg saloon - tc switch above radio - reg later 98
Will find out month of reg for both & post if that helps
« Reply #4 on: 21 April 2008, 10:15:44 »
Is the R reg a mini facelift (last letter of VIN a W)?
« Reply #5 on: 21 April 2008, 10:17:10 »
Excellent. So an early mini facelift.
Don't suppose you want to check how your Carin is connected to main body loom  ::)
« Reply #6 on: 21 April 2008, 10:20:31 »
Both mini facelifts - hids, bose etc!
« Reply #7 on: 21 April 2008, 10:25:59 »
I think it changed fairly early on in 1998 model year.  I think if you have TC button to left of radio, I think the plug to connect carin loom to body loom is missing.
So, now I need to find someone with early 98 one and carin to check how its wired in  :P
humbucker
  • Cambridgeshire
« Reply #8 on: 21 April 2008, 10:39:02 »
how the tc is wired in or the carin? point me in the right direction and i'll happily check it out for you
« Reply #9 on: 21 April 2008, 11:06:51 »
Its the carin bit I need checking. In passenger kick panel, carin loom (6 wires) joins body loom.  On later 1998 cars there is a 6 way connector, as described in http://www.omegaowners.com/forum/YaBB.pl?num=1202730965
Looking to see if there is something I've missed, before I start attacking the main loom  :'(
humbucker
  • Cambridgeshire
« Reply #10 on: 21 April 2008, 13:51:21 »
'k, as soon as i get a chance i will check it out for you. might not be til the weekend so if anyone else can answer you before then by all means go for it
« Reply #11 on: 21 April 2008, 15:23:31 »
my early mini facelift 98 MV6 also has TC by radio
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #12 on: 21 April 2008, 16:21:03 »
My mini facelift reflection (98 S) had the button above the radio.
Chassis no W0L0VBF69W1244216
first reg 05 08 1998
TuBy's new whipping boy.
« Reply #13 on: 21 April 2008, 19:58:52 »
TB
Elite estate - r-reg - first reg 13/5/98
Elite saloon - s-reg - first reg 1/8/98
Neither has satnav.
Hope this helps
« Reply #14 on: 21 April 2008, 20:50:23 »
I've moved my TC from button next to radio to above it :y
Still need to work out how they wired in Carin on the early 98s - though I'm guessing spliced in to loom  :'(
