Author Topic: Knocking noise  (Read 4910 times)
bighed
  • Shropshire
Knocking noise
« on: 15 April 2008, 07:07:52 »
Firstly i would like to apologise for all the questions. So heres two more  ;D I have got a light knocking noise coming from bottom of engine/gearbox on tickover.  :-/ When I slowly raise the rpm the noise goes after about 2000rpm. It also disappears after a good run (10 miles to work)  :-? Any ideas guys??
Also I had an oil leak from cam cover gaskets which was leaking quite badly. The oil used to start smoking from the heat of the engine. This was sorted on saturday but im still getting smoke from engine after a good run (again 10 miles to work) Is this the old oil burning off still??
TIA  :y
ians
  • Reading
Re: Knocking noise
« Reply #1 on: 15 April 2008, 11:25:09 »
Yes the old oil can take a while to burn off.
Tab
  • Telford
Re: Knocking noise
« Reply #2 on: 15 April 2008, 11:46:08 »
yeah old oil burning off the manifold, mine took about 2 weeks to completley disapear.
Dazzler
  • Haverhill, Suffolk
Re: Knocking noise
« Reply #3 on: 15 April 2008, 15:36:31 »
The noise may well be a tired oil pump, hence when revs increase and or the oil gets hot it stops :-/
bighed
  • Shropshire
Re: Knocking noise
« Reply #4 on: 15 April 2008, 16:40:55 »
How much and how easy to fix??
MutantCav
  • Gainsborough
Re: Knocking noise
« Reply #5 on: 15 April 2008, 16:45:17 »
If I knew where the oil pump was I could sort you one for very little money mate...I'm sure someone will be able to tell me :)
bighed
  • Shropshire
Re: Knocking noise
« Reply #6 on: 16 April 2008, 08:59:57 »
so do we defo think its the oil pump. Will ask one of the lads at the meet on sunday for a second opinion before I rip her to bits again  :y
mkaminski100
  • Basingstoke
Re: Knocking noise
« Reply #7 on: 16 April 2008, 11:31:04 »
Autobox oil pump? It's...inside the autobox. http://www.omegaowners.com/forum/YaBB.pl?num=1183142571 STEP 9 - oil pump.
It might be TC as well but I don’t know what kind of sounds it makes when knackered.
It's really hard to tell where the knocking sound is comming from (might be engine). You have to get under the car and check it (safety first)
bighed
  • Shropshire
Re: Knocking noise
« Reply #8 on: 17 April 2008, 07:05:13 »
mmmm, oil pump in gearbpx. never thought of that.  Would it be tc while engine is stood still tho?? Wouldnt it just make a bad noise while it was working if fubar'd  :-/
« Last Edit: 18 April 2008, 08:14:50 by bighed »
bighed
  • Shropshire
Re: Knocking noise
« Reply #9 on: 18 April 2008, 08:15:16 »
Anyone  :-/   :'( :'( :'(
« Last Edit: 18 April 2008, 08:25:04 by bighed »
Re: Knocking noise
« Reply #10 on: 18 April 2008, 09:25:53 »
FWIW, I have noticed a light knocking at idle from the sump area that disappears as soon as the engine is lifted above idle on several V6s I have worked on. I have no idea what it might be but I doubt it's worth tearing the engine apart for.
Jay w
  • Plymouth/Poole
  • omega gone
Re: Knocking noise
« Reply #11 on: 18 April 2008, 09:48:59 »
My old 2.5 used to do it, never bothered me, never got any worse
bighed
  • Shropshire
Re: Knocking noise
« Reply #12 on: 22 April 2008, 10:49:04 »
Hmmm. It became louder when I did an oil change on her last saturday so must be something oil related. Ok thanks for replies guys  :y
Re: Knocking noise
« Reply #13 on: 22 April 2008, 10:52:17 »
Any history of the engine having flush through it?
Was the oil very dirty at any point?
If yes to any of the above then its worth dropping the bottom sump pan off (not hard) and checking for crudd in the pan and on the oil pickup.
dene wakefield lad
  • wakefield yorkshire
  • my 1st love
Re: Knocking noise
« Reply #14 on: 22 April 2008, 13:02:13 »
change asap :-/
