Author Topic: noisy engine  (Read 1742 times)
sonabean
  • staffs
noisy engine
« on: 29 April 2008, 12:16:28 »
hi,i have 1995 omega estate,v6.engine has gone really noisy,dad thinks it water pump but sound like its coming from some pulleys and a belt thing,please help me [smiley=sad.gif]
MutantCav
  • Gainsborough
Re: noisy engine
« Reply #1 on: 29 April 2008, 12:27:08 »
Either way...wouldnt suggest driving the car until you know whats wrong for sure...if water pump fails it can cause high temperatures and head gasket failure...if its the cam belt tensioners rattling and on their way out...when they go, goodbye engine!
May, if its the aux belt area rattling (the belt that runs the water pump etc) be a bearing gone on the alternator or something like that??
« Last Edit: 29 April 2008, 12:29:09 by ShieldOfSteel »
mojo
Re: noisy engine
« Reply #2 on: 29 April 2008, 14:32:20 »
Definately worth checking it out properly buddy, as Chris advises.
My first omega had a water pump problem & the cam belt snapped on third lane of motorway, luckily with little traffic at the time of the evening i managed to veer on to hard shoulder.  The result was then a £1586 bill from my local friendly Vauxhall dealershiit, I mean ship.
« Last Edit: 29 April 2008, 14:33:42 by mojo »
Re: noisy engine
« Reply #3 on: 29 April 2008, 15:54:41 »
When was cambelt last changed?
sonabean
  • staffs
Re: noisy engine
« Reply #4 on: 29 April 2008, 19:49:00 »
no idea when cambelt was last changed,i only got car 6 weeks ago,great car tho
markey mark
  • SLady bitshorpe north lincs
Re: noisy engine
« Reply #5 on: 29 April 2008, 19:51:08 »
wont be for long with a noise at front of engine it will be scrap !! :-?
Re: noisy engine
« Reply #6 on: 29 April 2008, 19:54:04 »
cambelt and tensioners need changing every 40k or 4 years ,whichever comes first.you ought to get the belt changed and do the water pump and aux. belt while your at it.check the aux. belt tensioner while your there as they sometimes get noisy and fail.if the noise is from the front of the engine then doing these routine maintenance jobs will most likely cure it. :y
sonabean
  • staffs
Re: noisy engine
« Reply #7 on: 29 April 2008, 20:02:16 »
apparently the noise isnt coming from cambelt it seems like a pulley is loose
MutantCav
  • Gainsborough
Re: noisy engine
« Reply #8 on: 29 April 2008, 20:44:59 »
Tighten up the pulleys if its the aux belt pulleys...see if that helps
Re: noisy engine
« Reply #9 on: 29 April 2008, 20:54:02 »
i would still get it done asap,if you dont know when it was last done,it wont give any warning before it attempts to eat 24 valves  :y
DaveMarshall
  • Swindon/Cirencester
Re: noisy engine
« Reply #10 on: 29 April 2008, 21:11:41 »
Remove the auxillary belt then start the engine if the noise disappears you'll know it something related to that, while it's off check all the pulleys.
[SIZE=20]Vauxhall's breaking and wanted for breaking
E-Mail me at southwestvauxhallspares@yahoo.co.uk[/SIZE]
Re: noisy engine
« Reply #11 on: 29 April 2008, 22:41:20 »
A new tensioner pulley is very cheap and a 10 minute job to change ...  :)
makes these noisy V6's go back to quiet in just a few short moments .. :)
