Author Topic: 98 R 2.5 v6 FAILS TO START AFTER DRIVING 300 MILES  (Read 4385 times)
lordpsk
  • Gwynedd
« on: 06 May 2008, 13:38:57 »
Well fellow members, here's a puzzle for you, drove 300 to hotel by gatwick airport sa I was picking up a family member, stopped in hotel over night, next day car fails to start, call RAC, car is sparking and fires with a mist of easy start but no petrol delivery, pump not pumping.
Only 6 volts being delivered to petrol pump on RAC volt meg, conect switchable live supply to pump pump delivers petrol but then no spark.
So I have a car with 6volts at pump, no petrol and no spark.
Car has been bought by RAC relay back home but Vauxhall cannot look at it for two weeks due to Corsa and Vectra recalls.
Would like any suggestions or advise on what to look for/test or should I just put a gallon of petrol inside and put a match to it.
Re: 98 R 2.5 v6 FAILS TO START AFTER DRIVING 300 MILES
« Reply #1 on: 06 May 2008, 14:02:57 »
First off, read the fault codes.....might be a code 19.
Sorry, I don't pay any RAC or AA diag info any credence as its rarely any where near correct.
M Kerr
  • Birmingham
    • 2.5 GLS Omega, X Type
« Reply #2 on: 06 May 2008, 21:48:12 »
When you say delivers petrol how have you checked this!  I am assuming the engine turns over without any problem!  Have you got the engine management light on?  Have you done a paperclip test?
You might find vauxhall just as useless as the aa, just with your WALLET OPEN they'll eventually get it to go! :-/
lordpsk
  • Gwynedd
« Reply #3 on: 07 May 2008, 15:44:26 »
Hi fellow members,
Well the car decided to start last night, and agin this morning, then refused to start again when I was out.
Did paperclip test, well the fault codes are 135, 31.
135 telltale (checklight) voltage low I have'n a clue what that means.
31  no engine RPM signal, no engine running.
Anybody any further suggestions
any help would be gratefully received
MutantCav
  • Gainsborough
« Reply #4 on: 07 May 2008, 20:26:30 »
You would need to redo the test with the engine running to eliminate the crank shaft sensor...
lordpsk
  • Gwynedd
« Reply #5 on: 07 May 2008, 20:52:25 »
car has started again will redo and let you know the results
lordpsk
  • Gwynedd
« Reply #6 on: 07 May 2008, 21:06:36 »
Car started done test again, still showed up 135 as the only fault.
135 Telltale (checklight) voltage low.
anybody any ideas or should I change the crank sensor.
lordpsk
  • Gwynedd
« Reply #7 on: 08 May 2008, 10:59:40 »
Hi fellow members,
Does anybody know what this fault code means
Or should I change the crank sensors
flatmajor
« Reply #8 on: 08 May 2008, 20:13:05 »
hello there it looks like we have the same problem same diag i think but seems like my problem has gone away for now but as i siad same thing like when ive come home from work and the next morning it didnt start i had to give it a bump start. so ill be watching this thread to see what the out come is good luck.
Reflection 2.5 V6 24v
flatmajor
« Reply #9 on: 08 May 2008, 20:17:34 »
t
lordpsk
  • Gwynedd
« Reply #10 on: 09 May 2008, 16:06:04 »
Hi, Have bought new crank sensor as car is failing to start again and let you know how I got on, hopefully it will cure it or else its a waste of £56.00
lordpsk
  • Gwynedd
« Reply #11 on: 09 May 2008, 18:18:05 »
new crank sensor fitted car will not start, any suggestions anybody, not hearing much feedback, any help anybody would be appreciated
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #12 on: 09 May 2008, 19:00:12 »
Genuine Vx crank sensor?
I like red cars
Galahad
  • Bath
    • 2000 Omega 2.2 GLS
« Reply #13 on: 09 May 2008, 19:12:02 »
Have you tried removing the fuel filler cap?  Might be a blocked vent valve which means pump is struggling to suck fuel as its also trying to suck the tank flat.
Could also be a blocked fuel filter, and the pump has gotten progressively weaker as its tried to force the fuel through.
Good news if it is the pump, virtually any MPI pump will fit your Omega (Cavalier, Calibra, Astra, Vectra, etc)
« Last Edit: 09 May 2008, 19:18:34 by Galahad »
lordpsk
  • Gwynedd
« Reply #14 on: 12 May 2008, 16:29:42 »
Hi, Yes it was a genuine cranshaft sensor.
Tried releasing the petrol cap as suggested, also changed the fuel filter.
Car is still not running.
Any other suggestions gratefully received.
Regards
steve
