Author Topic: That's not right!!  (Read 4967 times)
Leomas
  • Boyne Valley (on loan)
  • Ooops what did I break this time?
That's not right!!
« on: 31 May 2008, 14:55:01 »
V6 has been running lumpy and a 'pre-test' ready for the MOT next week had it failing on emissions so thought I would give it some TLC.
Figured since I didn't know the history I would do the plugs as this is a really simple job right? Ha ha ha ha......
Got it stripped down enough to get at the plugs on the passenger side and it looks like the leads are not fully home although I don't have that magic clip thing that the manual shows for doing the job. Never mind I thought, put it back together and do the old paperclip test and see if that says anything....Yeah right....
Fit paperclip, ignition on...1-2, 1-2, 1-2, 1-9,1-9,1-9hang on a minute it's meant to be 3-1!  Start engine and watch again....1-2,1-2,1-2,1-9,1-9,1-9HELP
Anyone got any clues as to what I'm doing wrong, or alternatively what the fault with the engine might be?
« Last Edit: 31 May 2008, 14:56:01 by Leomas »
Recently 'learned up' and being more careful now, honestly.
Ummm except for where I fix one thing and break something else
johnnycboy
  • Colchester
Re: That's not right!!
« Reply #1 on: 31 May 2008, 15:10:43 »
normally, code 19 is crank sensor, not 100% but have u caught the sensor wire at the back of the engine whilst carrying out your lead and plug checks.
shanjon
« Reply #2 on: 31 May 2008, 15:13:06 »
i believe if you doing a paperclip test you will get a code 19 if the engine is not running, i presume the car was running when you did the test
« Reply #3 on: 31 May 2008, 15:13:28 »
yep, 19 is crank sensor, 12 is the beginning of the sequence
robbo299
  • luton, beds
« Reply #4 on: 31 May 2008, 15:18:44 »
Just did mine a few mins ago and i had 12 & 31 with the ignition off and 12 with engine running.
johnnycboy
  • Colchester
« Reply #5 on: 31 May 2008, 15:21:27 »
thats what u should expect,  code 19 will only come up if cs f**ked or on its way out. :)
Leomas
« Reply #6 on: 31 May 2008, 15:21:27 »
Anyone got a quick link to a piccie of where this delightful sensor is?  Just been looking but there is nothing obviously adrift and to be quite honest I don't know what I'm looking for.
« Reply #7 on: 31 May 2008, 15:24:08 »
The actual sensor is located next to the oil filter but its plug is by the engine lifting eye at the rear of the enging on the passenger side
johnnycboy
  • Colchester
« Reply #8 on: 31 May 2008, 15:25:25 »
here u go
http://www.omegaowners.com/forum/YaBB.pl?num=1174321688
as elite pete said with the connector location
« Reply #9 on: 31 May 2008, 15:32:44 »
Code 19 is a sign of a failing crank sensor.
The 19 is actualy an incorrect signal indication, i.e. the signal is 'not what the ECU expects', which does NOT sudgest a poor connection or the thing being disconnected (you would get a 31 with the engine running in this case).
So, change the crank sensor but, look at the connector shape at the rear of teh plenum to know which type to get.
« Last Edit: 31 May 2008, 15:36:54 by Mark »
Leomas
« Reply #10 on: 31 May 2008, 15:36:07 »
Thanks guys, just goes to show you shouldn't start something you are not qualified to finish....didn't get the plugs changed and now have a full day booked tomorrow to strip it back down to see what I've broken in the process, assuming the weather holds
« Reply #11 on: 31 May 2008, 15:37:22 »
Nothing broken, was most likely there before you started!
« Reply #12 on: 31 May 2008, 15:37:39 »
You wont be able to repair a crank sensor you will have to replace it :(
Leomas
« Reply #13 on: 31 May 2008, 15:43:23 »
OK, have to confess my embarrasment since, as so helpfully pointed out above) the fault may have been there all along, but without having paperclipped it before I started we will never know.
Note to self...either do it properly in a logical sequence (like in those procedure documents I spend large parts of my day writing) or give it to someone else to do.
« Reply #14 on: 31 May 2008, 15:44:53 »
Worry not though, the crank sensor is not hard to change :y
